Alternator/battery question
   / Alternator/battery question #21
Guys let me just give you a peice of advice. You dont want to ever pull a battery cable off any type of vehicle while it is running. Car, tractor, you name it, if it has a electronic module (todays car average 10+, todays tractors have a few) you run the high risk of damaging these modules due to improper voltage and voltage spikes.
   / Alternator/battery question #22
yep.. when that alt unloads.. charge voltage can spike...
soundguy
   / Alternator/battery question #23
As SJD said It sounds like brushes are worn or sticking. As a mechanic that is the first thing I would check after what you have said. Generally a blown diode just lowers the charge rate and the battery will often go flat if left sitting.
Well an update, I STILL haven't pulled the alternator, it seems like every time I plan on it, something else comes up, either that or I just don't use the tractor for a bit, and forget about it.
I just fnished doing a semi emergency tree trimming on a dying oak, that lost a 8" limb and sent part of it through the roof of my 5th wheel trailer, soooo the major limbs had to come down before they fall and CRUSH the trailer.
Now where was I?
   / Alternator/battery question #25
is the damage to the trailer roof repairable?
darn..
sorry to hear about the damage..
soundguy
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
2005 GROVE RT700E ROUGH TERRAIN CRANE (A50854)
2005 GROVE RT700E...
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A51222)
2016 FORD F-450...
KOMATSU PC130-8 EXCAVATOR (A50854)
KOMATSU PC130-8...
