Alternative to Lock-N-Lube.
   / Alternative to Lock-N-Lube. #2
   / Alternative to Lock-N-Lube. #3
First pic looks like a LNL while the others are different. Which is it? The jaws look like formed sheet metal.?
   / Alternative to Lock-N-Lube. #4
I ran across one in our local farm supply store. I don’t have a lock and lube so can’t compare.
It works fine.
   / Alternative to Lock-N-Lube. #6
I ordered one. It won't get here until the first week of December. What's that all about?
   / Alternative to Lock-N-Lube. #7
"first week of December"??
Direct ship from China?
   / Alternative to Lock-N-Lube. #8
I've had them all and nothing beats the Lock-N-Lube. It kills me to pay retail but it's the only one I have found that works. On my deep recessed fittings on my Woods mower deck, I use the Lock-N-Lube extra long version and that saves me a lot of grief when greasing things. Just my two cents.
   / Alternative to Lock-N-Lube. #9
So..oooo correct !!
   / Alternative to Lock-N-Lube. #10
there is an alternative that 4shorts has advertised on his channel. it is similar in function to a quick connect chuck on an air hose but once you pressurize it you cannot get it to release. example if a zerk doesn't take the grease.
they also make a valve that you can add that releases the pressure when it does happen. it is by univerco out of quebec. lifetime warranty. not made in USA but atleast it is designed in north america. not sure exactly where it is actually made.
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2005 TerraGator 8104 (A55301)
2005 TerraGator...
2000 Ditch Witch 3700DD Ride-On Trencher (A55787)
2000 Ditch Witch...
