Almost decided bx22/b7800
   / Almost decided bx22/b7800 #1
Anonymous Poster
Epic Contributor
I have been looking at buying a tractor for some time, putting it off more times than once, coal shovel starting to get old now though. I really don't know alot about tractors, but this forum has helped tremendously. Thanks to Everybody. I have looked at bx22 $15650 with belly mower. John deer 790 $21,500 backfoe/loader, and now b7800 $20,000 bl4690 with bracket for subframe/ loader 60mmm mower. /forums/images/graemlins/confused.gif Almost went today to order 7800. (big step for me) Mayby tommorrow. Any one else lost this much sleep reading this chat line? /forums/images/graemlins/wink.gif
   / Almost decided bx22/b7800 #2
Whatcha gonna do with the tractor the most? How land are you taking care of with the tractor. There's a few tractors in between the BX22 and B7800.
   / Almost decided bx22/b7800 #3
Shane, welcome to the forum.
Back in 2000 when I started looking, the BX22 and B7800 weren't out yet. Since I had convinced myself I wanted a backhoe, and for a variety reasons chose orange, that meant a B7500, B2410, B2710 or B2910. When push came to shove and I looked at all that money on the table, I felt the B2910 with the 7 1/2' backhoe (I got a Woods 7500) was the most bang for the buck.
I opted for the B2910 over the B2710 for some of the creature comforts, and I'm glad I got them. The telescopic lower links sure make hooking up implements a relatively painless task, and the suspension seat is also well worth it if you have any back problems. I have sometimes used the cruise control to "brake steer" when using the bucket for snow removal.
For me, I figured the extra few $$$ between the B2910 and the B2710 (and now the B7800) are well worth it over the life expectancy of the tractor.
Before you sign on the dotted line, I would at least get a quote on the same package with a B2910.
Whatever you get, it'll sure beat a shovel!
Good Luck,
~Rick
   / Almost decided bx22/b7800 #4
I am toying over the same problem, for right now the BX22 will do, but down the road with a new house and large land I might want a larger tractor? Im glad Im not the only one with these questions/problems.
KC
   / Almost decided bx22/b7800 #5
You've got a pretty broad range of models listed there. If you're doing a lot of mowing, I hear the BX series is top notch. If you want to do a lot of digging, the B7800 would probably be better, although for that kind of $$$ you really should check out the slightly larger tractors. Can't give you much advice on the JD (don't know the models), but what I found is that for equivilant models the JD was a bit more $$$.
Best question so far is, "what are you going to do with it?"
I live on a hill with about 33 acres mostly hillside 900 foot of drive, 1500 feet or more of ditches to keep clean. Need to dig a water line up the drive. maby 3 acres to mow. gravel parking lot to grade.like to have a garden as well. Snow removal for winter time. I guess that is just a start. /forums/images/graemlins/smile.gif
They told me the 2910 would be about $1400 more. I have already jump up quit a bit from the bx22, don't know if I can stand much more. (or should I say wife). I also need to fill in my yard more and redig some septic lines.
<font color="blue"> b7800 $20,000 bl4690 with bracket for subframe/ loader 60mmm mower. </font>
Wow...that sounds like a really good price for the b7800 with loader, back hoe and MMM.
Let us know if that is what it ends up being if you do get the B7800...If I remember right I paid a bit over 24K for about the same thing, but b2819 with an extra backhoe bucket and tooth bar...last summer....
I did not have the option of a subframe for the backhoe...it was a 3ph mount last year...
I hope he did'nt make a mistake. One dealer did quote 22,650 but with a 6 1/2 bushhog backhoe. I will let you know for sure.
   / Almost decided bx22/b7800 #10
Sounds like a good price on the 7800 package. I was quoted $23, 286 for a similarly configured package (exception was this included a Woods 6500 backhoe).
2016 Ford F-550 4x4 12ft Landscape Dump Truck (A50323)
2016 Ford F-550...
2019 Ram 1500 Pickup Truck (A50323)
2019 Ram 1500...
2016 Ford Focus Sedan (A50324)
2016 Ford Focus...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
