Allis Chalmers B and CA
/ Allis Chalmers B and CA #21
flusher said:
Thanks for the info. I'll check the tractor again today.
Finally found the S/N for that WD tractor I'm looking at. It was where you said it would be, but nearly invisible.
It's WD94898, making it a 1951 model. Seller thought it was 1954.
The engine S/N is WD303024PA, which correlates to a 1951 model also
(see AC WD Engine to Tractor SN Correlation.
Don't know what the "PA" means in the engine S/N. Any suggestions?
Owner says it's been parked for over 4 years. No battery, fluids drained. Need to see if it runs before making an offer. Concerned that the engine might be stuck. What's the simple and quick way to check this without actually running the engine?
/ Allis Chalmers B and CA #22
That age tractor may still have a hand crank backup system... just don't break a arm! Use to hand crank my 1949 Farmall when I was about 12 years old.
mark
/ Allis Chalmers B and CA #23
/ Allis Chalmers B and CA #24
BTW: received an answer to my "PA" question on the unofficial Allis Chalmers website:
PA indicates a gas engine with 5.7:1 compression ratio; GA indicates 5.5:1
/ Allis Chalmers B and CA #25
To check if the engine is stuck pull the plugs out, put it in high gear and watch the fan as you try to roll back tires by hand.
/ Allis Chalmers B and CA #26
Sounds like a plan. Thanks.
/ Allis Chalmers B and CA #27
Can also pull plugs, block clutch and try to bar it over.. or grab a fan belt..
soundguy
/ Allis Chalmers B and CA #28
If it has a hand crank, can't you just put the trans in neutral, and try to crank it over a little? Even if there's no hand crank, pulling the plugs, and turning any of the front pulleys has always worked for my on the ol' trucks I've fooled with... I've put a ratchet on the crank bolt a time or 2... prybar between the waterpump/fan hub bolts... anything to get the crank to move a little...
Blocking the clutch was mentioned earlier.... if the motor is seized up, the clutch may well also be... trans in neutral should let it spin... right?
/ Allis Chalmers B and CA #29
Thanks for the suggestions. Both sound like the thing to do.
New/Unused Wolverine 48in Mini Combination Bucket (A65583)
New/Unused...
Ford 3910 Tractor (A65579)
Ford 3910 Tractor...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
Landhero 10' x 10' Metal Shed (A66408)
Landhero 10' x 10'...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2015 Jeep Renegade Latitude SUV (A64557)
2015 Jeep Renegade...
