Pat's Easy Change Allis chalmer wd
/ Allis chalmer wd #1
Otrenche
Carl Junction, Mo
Allis Chalmer WD
Hello ; can any body help me out on wich 3 point hay spear will fit my allis chalmer wd , thank you
/ Allis chalmer wd #2
Is it modified from its original configuration to accept 3 point implements? Ken Sweet
/ Allis chalmer wd
It has the front hidraulic system lifter ; i just bough it , this is a whole new world for me , thank you .
/ Allis chalmer wd
Thank you guys for you're help , I can send pics if that help .
/ Allis chalmer wd #5
does it have a 3 pt hitch or snap couple? The first picture is a conversion of the older snap coupler system, they may look different as there are many ways to convert them. The second picture has the snap coupler system.
/ Allis chalmer wd #7
Just google "tractor supply 3 pt spear" and you find several types $200 to $300.
/ Allis chalmer wd #8
If you have the 3pt hitch adapter like you said you do any Category 1 implement should fit. Double check the holes in the ball of the arm to see what shaft size it it to determine the category you need. If you have a higher number you can always go down not up. Cat0 Size=5/8" Cat1=7/8" Cat2=1 1/8"
Hope this helps
129d (A63291)
129d (A63291)
2014 Mitsubishi Outlander Sport SUV (A61574)
2014 Mitsubishi...
2020 Deere 544L (A60462)
2020 Deere 544L...
2022 EZ-GO ELITE...
HAY MASTER DOUBLE SQUARE FEEDER (A63291)
HAY MASTER DOUBLE...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
