Pat's Easy Change Allis chalmer wd
/ Allis chalmer wd #1
Otrenche
Carl Junction, Mo
Allis Chalmer WD
Hello ; can any body help me out on wich 3 point hay spear will fit my allis chalmer wd , thank you
/ Allis chalmer wd #2
Is it modified from its original configuration to accept 3 point implements? Ken Sweet
/ Allis chalmer wd
It has the front hidraulic system lifter ; i just bough it , this is a whole new world for me , thank you .
/ Allis chalmer wd
Thank you guys for you're help , I can send pics if that help .
/ Allis chalmer wd #5
does it have a 3 pt hitch or snap couple? The first picture is a conversion of the older snap coupler system, they may look different as there are many ways to convert them. The second picture has the snap coupler system.
/ Allis chalmer wd #7
Just google "tractor supply 3 pt spear" and you find several types $200 to $300.
/ Allis chalmer wd #8
If you have the 3pt hitch adapter like you said you do any Category 1 implement should fit. Double check the holes in the ball of the arm to see what shaft size it it to determine the category you need. If you have a higher number you can always go down not up. Cat0 Size=5/8" Cat1=7/8" Cat2=1 1/8"
Hope this helps
JLG Aerial Lift Service and Maintenance Manuals (A63117)
JLG Aerial Lift...
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
Caterpillar 988B Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 988B...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
Zero Turn Mower (A59231)
Zero Turn Mower...
Caterpillar 910 Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 910...
