All day making little boards out of big boards
   / All day making little boards out of big boards #11
Very nice Cliff! If I ever find the time to get back into my woodshop seriously, that's the jig I'd get. I have a cheapy now and it's very frustrating to have the boards move around as the clamps do not get tight enough.
Nice work, be sure to post more as you progress.
OK,
Pins are done, so here are some more photos.
1. Pins all stacked up.
2. Close up of the pins
3. Pins in the jig with a backerboard to reduce tearout.
4. Router set up for anyone interested. The Leigh set of bits from CMT is behind the router. I got a good deal on the set several years ago at a wood show.
The leigh jig isn't for everyone. It's complicated to set up and takes some time. The real difference is that it will do dovetails which aren't regular, that is, obviously machine made. The other jigs need the drawers to be multiples of 1/2 inch high and the pins and tails are always 1/2 inch. The Leigh jig isn't cheap either. I bought mine in the 80's, and I'm getting my use out of it, but for most use, a good standard jig will do great.
The router I've used here is a standard Porter Cable. Don't skimp on the router or the bits. The router should be able to do the work without slowing down, and good bits help that too. I like small powerful routers, like this PC. I have a big Bosch plunge router, but I usually use this PC. It's just right for almost everything. The most important thing in the router is the collet. Less expansive routers will look good on paper, but the little things will eat you up, like a collet that comes lose, a depth setting that's finicky, a base that's not square to the shaft etc. It's just like a quality tractor. You pay extra for the stuff you wouldn't notice until you work with one that's really designed and made well.
I will post more as things come together. These built-ins aren't going to be beautiful. They are made to match (look and feel) the pine molding already in the house. If I'd made them out of tiger maple and curly cherry with Walnut pulls, they would look great by themselves, but would look stupid in the room they are going in.
Cliff
Here are some more photos.
1. a side shot of a drawer.
2. A mountain of shavings from the planer.
Cliff
   / All day making little boards out of big boards #14
Cliff,
Those drawers are too cool!!! It's nice to see how you did them and how nice they came out.
What are you going to do with you shavings mound? I alwasy put mine around my plants as mulch.
Thanks,
Eddie
EddieWalker said:
Cliff,
Thanks. It never ceases to amaze me how long everything takes, but I'm liking the results.
EddieWalker said:
What are you going to do with you shavings mound? I always put mine around my plants as mulch.
I do that sometimes, and somethimes I give the clean shavings to Dave Nay (if it's all pine) for his horses. If I use them as mulch, I have to wet it down, or it blows it around too much.
Cliff
   / All day making little boards out of big boards #16
Very nice Cliff. I have been stuck on softwoods for a few years now and the pine looks very nice milled and joined that way.
Keep the pics coming
Regards,
Kevin
   / All day making little boards out of big boards #17
Nice work.:D
Wonder if one could package and sell the savings as firestarters??:D In novelty stores!;)
   / All day making little boards out of big boards #18
Afternoon Cliff,
Very nice !!! Did you rough mill all that pine flat and down to thickness ?
I will concur, that is a bunch of work to do. I know the feeling well ! :)
Nothing like tight joints ! :)
Thanks for the pics !
scott_vt said:
Afternoon Cliff,
Yes I did. Even if you get planed and squared wood, you still have to plane and square it yourself because the the wood changes too much by the time you get it and leave it sit in your shop for a while to acclimatize. All boards warp, bow, or twist to some extent after you get them.
In this case, this is all home depot lumber, so, yea, I had some work to do (but it is cheap). You can't go to the lumber yard and get northern white pine around here, even the good yards. They just have SPF or hardwoods.
Cliff
OK, photo update time.
Today, I fitted all 10 drawers together and made the little adjustments to make them fit nicely. I labeled all the parts so they go back together the same way later. I cut and fitted the 1/4 inch Birch plywood for the bottoms. I also cut and fitted the sides for the carcases.
The first two photos show the groves.
The next is a photo of the stack of drawer bottoms.
The next is a fit together drawer
The final shows the side of the cabinet. There will be a moulding around the side panel when it's all done.
Cliff
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
Mobile Toilet With Shower (A55758)
Mobile Toilet With...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55788)
2016 Chevrolet...
2018 Chevrolet Colorado 4x4 Ext. Cab Pickup Truck (A55788)
2018 Chevrolet...
