All copper ground clamp
/ All copper ground clamp
Did you find any pure copper ground clamps, or did they all turn out to be copper alloy-bronze-brass like we told you?
Yup;
One by the name of nunaya
Sent from my iPhone 5s 64Gb using TractorByNet
/ All copper ground clamp #32
I did some searching and I don't think there are any pure copper clamps due to reasons stated above - the copper is too soft. Tweco's clamps claim to be 98% copper. Can't get much better than that. I totally get the desire to have low resistance but think of the whole system. The resistance in a 98% copper clamp will be much lower than the steel you are welding on or even your welding rod. I bet the welding rod itself is the biggest bottleneck to the electric flow as they are small in diameter compared to everything else in the chain.
/ All copper ground clamp #33
The rod is designed to be that. You want the rod to arc and melt before anything else
/ All copper ground clamp #34
Obviously but you only want the tip melting. I was saying you have more resistance in the length of the rod as in back up by the electrode holder than probably anywhere else. Certainly the conductivity of a ground clamp that is gold, silver, copper, steel whatever is a lot better than an 1/8" rod.
/ All copper ground clamp #35
just reading this thread makes me realize why road rage is out there !people on the edge!!!!
K
Which member are you referring to and why?
Rock knocker has been "opinionated" but that's all it is his; his opinion!
/ All copper ground clamp #37
I think there are people with a chip, and ready to tell anyone about it, that's all. Everyone has an opinion and being aggresive serves no purpose and hinders constructive conversation. and with that, I have said enough and will go back to my listening mode.
Yup I hear you there!
Must be nice to know everything and never be wrong though...
/ All copper ground clamp #39
Unless you are running a Hot Pulse or Twin Pulse 300+amps..The clamps discussed on here are not needed. I use them too but a 250 amp transformer unit does not require anything special for grounding. If you want one it's all good but you don't need it. A $5.00 clamp will work as well as a $50.00 one on a 252. just sayin.
Yomax;
I know your dislike of the 252...
Point taken; thanks for saving me $50!
2018 Toyota Tundra Pickup Truck, VIN # 5TFRM5F11JX133691 (A61165)
2018 Toyota Tundra...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
iDrive TDS-2010H...
2004 Bulter Pole Trailer (A60352)
2004 Bulter Pole...
