Aircraft/Tow Adaptor
   / Aircraft/Tow Adaptor #11
I have a spare PT QA plate that I've welded several things to. One is a 2" receiver tube. I slip a ball hitch in there to move my 18' car hauler trailer several times a year. I never raise the trailer jack. I just drive up, put the ball under it, lift and go.
I'm on flat ground. Would never do that on a hill.
The trailer is 1500# empty. I've had it loaded with firewood to easily 7000# total. It's fine on the paved driveway and flat grass, but even the slightest of hills and/or the trailer tires sink bit into the grass and then it's a struggle.
Also, as others have mentioned, how the weight is distributed on the trailer makes a huge difference. Sometimes I can't lift the trailer jack off the ground. Then I throw the firewood from as far forward on the trailer to behind the axles until I can lift it. Then off I go.
But again, ON FLAT GROUND. šŸ™ƒ I could see a trailer hopping off or just plain dragging a little PT down a hill. Be safe.
   / Aircraft/Tow Adaptor #12
I am not sure how much the power trac trailer with attachments weigh but i move mine in my yard all the time, it is heavy enough that i cant turn all the way without lifting my rear end of my 2425, but it will move it all over the yard even with gentle the slopes i have. On the trailer is the auger unit 12,19 and 24 inch auger bits , power rake, 4 foot tiller , smooth bucket, grappler bucket, ditch wich and stump grinder. It lets me know its there but moves it ok. I dont have a ball mount to hook into the trailer so i utilize the safety chains and hook them on the Quick attach and away i go. If the trailer trys to get away from me i can tilt the quick attach and drop the chains as a last resort putting tounge on the ground or just dropping the trailer toungue to the ground to controll the situation .
Thanks so much for this reply - will make sure I try this on flat ground. Bill
   / Aircraft/Tow Adaptor #14
Yep! (y)
Also, I and many others have found several good uses for a quick attack plate with a 2" receiver tube welded to it. Pretty handy. I use mine for the mentioned trailer ball hitch and a ring hitch that I use chains on to drag/lift things like firewood. Others have made small boom poles and such. Pretty handy.
Very useful information! I just bought this site unseen and it is on it's way to Tazewell to be checked out today. Hope it turns out well. It's 2003 with 650 hrs.
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2223EB000633, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
60in Forks (A56857)
60in Forks (A56857)
2004 JOHNSTON STREET SWEEPER (A58017)
2004 JOHNSTON...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Adams 16T Tender Body (A56436)
Adams 16T Tender...
