Air tools rant
   / Air tools rant #61
The large GE jet Engines are running about $10 mil a copy for new??It is Engine, not motor..
   / Air tools rant #62
Jonyyuma,:)
Yes, that price sounds about right. But you can buy an almost wore out Pratt and Whitney JT8-7b or -9 for pennys.;)
I will remember to tell my co workers when we are working on them to call them engines, not motors.:laughing:
hugs, Brandi
   / Air tools rant #63
A jet engine is nothing more than a giant air compressor.
   / Air tools rant #65
V1Rotate,:)
Which is the second part of the 4 step process of how a jet engine operates.;)
Suck, Squeeze, Bang, Blow.:thumbsup:
hugs, Brandi
   / Air tools rant #66
It's interesting than a turbine engine uses the same 4 cycles that a piston engine uses. Except that all 4 cycles happen at the same time on the turbine.
   / Air tools rant #67
A good 5hp single phase motor is $500 or more!:rolleyes: Unless I can find a good used motor, I'm not needing that much air.
That depends how good. You can get better prices on the 3450 RPM ones. I have one like this.
Leeson Air Compressor Electric Motor 5 HP, Model# 116511 | Motors | Northern Tool + Equipment
Served fine for 10yrs and still will if I reconnect that compressor. I would run it an hr or more continuous sand blasting with my Kellogg American compressor. Current at 160PSI cuttoff pressure was 25A ... an overload.
larry
   / Air tools rant #68
You are correct.:thumbsup:
larry
   / Air tools rant #69
Well, those things that spit fire out of the bottom of a space ship are called rocket motors by the people in that industry.
... Corrupting the language. Definitive words are losing their meaning.
larry
   / Air tools rant
Those leeson motors are very good, my dad has one on his old delta table saw, the motor has been used quite a bit for like 20 years, and it is still working perfect.
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
Excavator Mulching Head (A50774)
Excavator Mulching...
300-gal Poly Sprayer 60ft Boom (A52128)
300-gal Poly...
2021 CATERPILLAR 302.7CR EXCAVATOR (A51242)
2021 CATERPILLAR...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
