Air tools rant
/ Air tools rant #62
The large GE jet Engines are running about $10 mil a copy for new??It is Engine, not motor..
Jonyyuma,:)
Yes, that price sounds about right. But you can buy an almost wore out Pratt and Whitney JT8-7b or -9 for pennys.;)
I will remember to tell my co workers when we are working on them to call them engines, not motors.:laughing:
hugs, Brandi
/ Air tools rant #63
A jet engine is nothing more than a giant air compressor.
/ Air tools rant #65
V1Rotate,:)
Which is the second part of the 4 step process of how a jet engine operates.;)
Suck, Squeeze, Bang, Blow.:thumbsup:
hugs, Brandi
/ Air tools rant #66
It's interesting than a turbine engine uses the same 4 cycles that a piston engine uses. Except that all 4 cycles happen at the same time on the turbine.
/ Air tools rant #67
A good 5hp single phase motor is $500 or more!:rolleyes: Unless I can find a good used motor, I'm not needing that much air.
That depends how good. You can get better prices on the 3450 RPM ones. I have one like this.
Leeson Air Compressor Electric Motor 5 HP, Model# 116511 | Motors | Northern Tool + Equipment
Served fine for 10yrs and still will if I reconnect that compressor. I would run it an hr or more continuous sand blasting with my Kellogg American compressor. Current at 160PSI cuttoff pressure was 25A ... an overload.
larry
/ Air tools rant #68
You are correct.:thumbsup:
larry
/ Air tools rant #69
Well, those things that spit fire out of the bottom of a space ship are called rocket motors by the people in that industry.
... Corrupting the language. Definitive words are losing their meaning.
larry
/ Air tools rant
Those leeson motors are very good, my dad has one on his old delta table saw, the motor has been used quite a bit for like 20 years, and it is still working perfect.
/ Air tools rant #71
larry
Thanks, I need the 1740 rpm model. It's just that it's low on the totem pole financially speaking.
/ Air tools rant #72
The motor vs engine topic is interesting. I did a quick google search on the subject and found engine has been around for along time, and was used to describe many different things. Motor also has an interesting origin
World Wide Words: Engine and Motor
JB.
/ Air tools rant #73
So I have one question, why do they call Detroit the MOTOR city? Do they make electric motors? :laughing:
/ Air tools rant #74
Let's look at word origins: motor
mid-15c., from L. motor, lit. "mover," from movere "to move" (see move). From 15c. as "controller, prime mover" (in reference to God); sense of "agent or force that produces mechanical motion" is first recorded 1660s; that of "machine that supplies motive power" is from 1856. With explosive use 20c. as a comb. form of motor-car (1895). Motor-boat is from 1902. First record of slang motor-mouth "fast-talking person" is from 1971.Online Etymology Dictionary
engine
c.1300, "mechanical device," also "skill, craft," from O.Fr. engin "skill, cleverness," also "trick, deceit, stratagem; war machine" (12c.), from L. ingenium "inborn qualities, talent" (see ingenious). At first meaning a trick or device, or any machine (especially military); sense of "device that converts energy to mechanical power" is 18c., especially of steam engines.
/ Air tools rant
Think about marine for a second, there are outboard MOTORS, not engines, and there are inboard MOTORS, not engines. Even though they are internal combustion engines, they are called motors.
/ Air tools rant #76
I just put MOTOR oil in my ENGINE :confused2:
I have no problem with someone referring to a vehicles power plant as a motor. It doesn't really work the other way though, "Electric Engine" doesn't sound right.
Like was mentioned about the NASA rocket propulsion units, they interchange the words engine/motor, so if it's good enough for those egg heads it's OK with me.
JB
/ Air tools rant #77
I use engine oil in my engines, altho it is mislabled such that the distinction is lost.:( It takes an engine to drive a motor. It takes a self sustaining prime mover at the head of the line to cause motoring -- hence motor car, cycle, boat, etc -as subsidiary systems undergoing motoring. In many cases a motor will be used to start the engine.
larry
SCAN TO RECEIVE TEXT UPDATES (A63291)
SCAN TO RECEIVE...
2014 John Deere 7230R Tractor (A63111)
2014 John Deere...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
2025 X-Pro Victor Mini Dirt Bike (A61574)
2025 X-Pro Victor...
2016 International Workstar 7500 T/A Dump Truck (A61573)
2016 International...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
