ArlyA
Super Star Member
- Joined
- Mar 18, 2016
- Messages
- 13,516
- Tractor
- Outlander1000 6x6, Ego lawn mower and shopping for tractor
Another good video about the poor visibility the P-63 had.
I'll guess that they were flying within 10-20 mph of each other.Very legitimate question. Some probably know the answer already, but I have not yet heard it.
What is more of a concern for me is the differential in speed while flying at the same or similar altitude. To me, that was an obvious factor. If the two planes were traveling at similar speeds I doubt this would have happened.
The speed differential is a known source of problems. It's why most uncontrolled airports have a traffic pattern altitude of 800' or 1,000' above the runway for piston aircraft, and typically 1,500' above the runway for turbine aircraft. The turbine aircraft are operating at faster speeds.
I came to that conclusion as well, however, using common sense...It'll probably come down to what it almost always comes down to...
Pilot error.
He used to be one of our council members. I didn't know him personally, but there are a lot of commercial pilots living here.Another member on TBN knew the B17 pilot.
Very sad indeed, they had no chance after the collision.
Yep, very sad.Both aircraft in blind spots. Collisions like this happen often, typically with small aircraft at uncontrolled fields. Sad
