Tires air in front tires
   / air in front tires #2
Are they new. Seating pressure is about 35psi. I like to run the fronts at 15-22 psi depending on the tractor.
   / air in front tires #3
Is the max inflation pressure shown on the sidewall? If it is a 7 - 16 with 6 ply rating the pressure would be 36 psi. The spec sheet says 7.2 - 16 but I don't find that size in Bridgestone - Firestone or Titan - Goodyear books.
   / air in front tires #5
I have 7.2 - 16 Goodyear front tires on my L3010. Manual says 22 psi. Loader manual says to increase to 26 psi with loader.
   / air in front tires #7
Tires are designed to carry a full foot print on the ground. This does change depending on load so if you have a loader and enjoy carrying large loads you will need more air pressure then if you don't have a loader and might be using the three point to carry loads.
The pressure makes a big difference as far as ride as well so it is important not to over inflate same as having the tires filled.
   / air in front tires #8
After you determine your tire size this is what the tractor and loader manuals calls for.
According to this chart 40psi is too much but to confirm that your tire should have a max tire pressure rating.
I have the r4 tires on my 3800 but from what I've heard the r1 tires are a softer tire so maybe your dealer airs the front tires
up with a little extra psi when leaving with a loader.The manual doesn't support that assumption tho.
front tires sizes
5.00-15 4pr =32psi
7-16,6pr=26psi
23x8.50-12 4pr=23psi
25x8.50-14 6pr=23psi
27x8.50-15 6pr=30psi
rear tire sizes
11.2-24 4pr=14psi
13.6-16 4pr=14psi
15-19.5 6pr=30psi
   / air in front tires #9
the best an safest thing todo about tire pressure is look in your tractor manual ango from there.
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2002 Wilson Hopper Bottom Trailer (A50514)
2002 Wilson Hopper...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
Land Honor Skid Steer 3 pt Hitch Adapter (A50515)
Land Honor Skid...
2022 CATERPILLAR 272D3 WHEELED SKID STEER (A51242)
2022 CATERPILLAR...
