Air Hose Fitting--Plastic OK?
/ Air Hose Fitting--Plastic OK? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Have had this coiled hose around for several years but haven't used it because the end fittings are 3/8" MPT which don't play well with 1/4" quick couplers. So I made an adapter out of 1" delrin but wondering about safety.
The OD of the 3/8" internal pipe thread is about 0.700" so that leaves about 0.150" wall thickness with the 1" OD delrin. I understand and appreciate all the caveats about using PVC for compressed air lines but wondering about the worst possible scenario with regard to the delrin adapter fitting.
I realize that metal adapters are available but just trying to minimize the weight at the ends of the hose.
/ Air Hose Fitting--Plastic OK? #2
Why don't you get a 3/8" FNPT coupler and screw it directly to the hose?
I don't think that such an animal is available, near as I can tell. I see only 1/4" pipe threads available for 1/4" quick couplers and 3/8" pipe threads for 3/8" quick couplers.
/ Air Hose Fitting--Plastic OK? #4
NOPE!
Adapters are available.
I thought I was going to need some, and found them available on Amazon.
/ Air Hose Fitting--Plastic OK? #6
Milton makes a model number 718 that is 3/8" FNPT for Type M. That's a common one.
/ Air Hose Fitting--Plastic OK? #7
The cheap made in china ones leak or don't last
/ Air Hose Fitting--Plastic OK? #8
npalen, I'm sorry I sort of took this off track from your question. It looks like you did a nice job making that fitting. If it were on mine, I wouldn't be worried about it. I would expect any failure would be a crack and leak, which wouldn't be a safety concern. I'll bet that outlasts your hose though. :thumbsup:
Oh, no problem.
I do see this Model 718 but the price shocked me.
3/8" FNPT M Style Coupler | Milton Industries | Miltonindustries.com
I had checked on Amazon and didn't find anything in a 1/4" coupler with 3/8" pipe thread.
I'll go with the homemade adapters and agree that they will probably outlast the hose. I figured someone was going to say that plastic fittings were a death warrant on air lines.
/ Air Hose Fitting--Plastic OK? #10
I worked in a big factory using brand name air hoses and very good couplings. Over the years I saw or fixed a few hundred of them that either were ripped off, flew off, knocked off etc and hoses just started flying around. Nobody ever got hurt, not that it couldn't happen.
I don't think I would use that system for anything over a hundred psi though. If you got a heavy duty high PSI compressor I would be really careful with that setup.
My compressor is set at 150 psi. I had planned to use UHMW for the adapters but only had delrin on hand. I would feel better with the strength of UHMW.
/ Air Hose Fitting--Plastic OK? #12
/ Air Hose Fitting--Plastic OK? #13
If your worried about an exploding fitting harming someone just get some heat shrink and install. It won't keep the fitting from exploding but it will contain the shrapnell.
/ Air Hose Fitting--Plastic OK? #14
You did a nice job making that adapter out of Delrin. I can't definitively attest to it strength but I would feel safe using it
Of course I TRY to avoid using adapters or any extra fittings whenever possible. Just extra potential leak points.
Here's a couple of my coiled hoses with (albeit 3/8") couplers.
/ Air Hose Fitting--Plastic OK? #15
Delrin is pretty strong stuff, and stronger than UHMW by 6-9X depending on the property. I suspect it will be fine. We used to machine a lot of parts out of delrin when I worked in a machine shop in the 90s and I really came to like it.
/ Air Hose Fitting--Plastic OK? #16
Oh, no problem.
The Milton 718 is listed for $9.95 on Amazon.
I am not shocked at that price.
Interesting as I didn't know delrin was that strong compared to uhmw. It sure machines a lot better than uhmw. Deburring uhmw can be a real pain.
Edit: I'm seeing 6000 psi tensile strength on uhmw and about 9000 on delrin.
UHMW stretches 300% before breaking compared to delrin at 25% stretch.
That would account for why uhmw can be cold formed perhaps?
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
New/Unused 3 Point Receiver Hitch Attachment (A65583)
New/Unused 3 Point...
2009 Featherlite Race Car Hauler Enclosed Trailer (A62613)
2009 Featherlite...
Quick Attach Backing Plate (A65579)
Quick Attach...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A65643)
2012 INTERNATIONAL...
