air handler coils froze up - question
   / air handler coils froze up - question #61
I will have to check out the line and maybe add a line from the pan.
I knew that when I bought my current place that the attic was a stupid place to put the air handler. Think about it, cold in the winter and hot in the summer. Sounds like dumb and dumber to me.
I told my builder, "No ductwork or air handler in the attic". People think the ducts are insulated so not a problem. Maybe an R value of 3 or 4 against extreme temperature differences (100 degrees or more)
QUOTE]
Could be worse.. I know people with hot water heaters in the attic!
As an update to this thread.. I usually have only been running the ac for a few hours before bed.. so not a real test to see if it was gonna freeze up again.. well last night I did tghe endurance test.. ran it from about 8pm thru about 7am.. worked fine...
soundguy
   / air handler coils froze up - question #63
soundguy[/quote]
Hey, I have my solar hot water tank in the attic! I did put 5 inches of Styrofoam insulation around it. I doubt if the heat leakage is significant. That does not bother me as much as water leaking potential. A 2 inch pan may not be enough.
as long as it's got a 2" drain it should be fine! :)
soundguy
   / air handler coils froze up - question #65
soundguy
It's a one inch. I think a 2 inch would require a hole so big it in the pan side that there would be nothing left of the pan side.
then thats a problem ;)
soundguy
WOLVERINE TL-12-72W - 72" HYD TILLER (A54756)
WOLVERINE...
1992 Peterbilt 377 Sleeper Cab (A55301)
1992 Peterbilt 377...
20 Ton Hydraulic Bottle Jack (A55787)
20 Ton Hydraulic...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A55787)
2017 Kawasaki Mule...
New JMR 40" Mini Skidloader Flat Bottom Grapple (A50775)
New JMR 40" Mini...
JOHN DEERE 8335RT TRACK TRACTOR (A54756)
JOHN DEERE 8335RT...
