air handler coils froze up - question
   / air handler coils froze up - question #61
I will have to check out the line and maybe add a line from the pan.
I knew that when I bought my current place that the attic was a stupid place to put the air handler. Think about it, cold in the winter and hot in the summer. Sounds like dumb and dumber to me.
I told my builder, "No ductwork or air handler in the attic". People think the ducts are insulated so not a problem. Maybe an R value of 3 or 4 against extreme temperature differences (100 degrees or more)
QUOTE]
Could be worse.. I know people with hot water heaters in the attic!
As an update to this thread.. I usually have only been running the ac for a few hours before bed.. so not a real test to see if it was gonna freeze up again.. well last night I did tghe endurance test.. ran it from about 8pm thru about 7am.. worked fine...
soundguy
   / air handler coils froze up - question #63
soundguy[/quote]
Hey, I have my solar hot water tank in the attic! I did put 5 inches of Styrofoam insulation around it. I doubt if the heat leakage is significant. That does not bother me as much as water leaking potential. A 2 inch pan may not be enough.
as long as it's got a 2" drain it should be fine! :)
soundguy
   / air handler coils froze up - question #65
soundguy
It's a one inch. I think a 2 inch would require a hole so big it in the pan side that there would be nothing left of the pan side.
then thats a problem ;)
soundguy
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
PALLET OF DISHES (A58374)
PALLET OF DISHES...
FORD TRUCK BED MAT (A52708)
FORD TRUCK BED MAT...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
MILWAUKEE 14" Abrasive Cut-Off Machine (A59076)
MILWAUKEE 14"...
