air handler coils froze up - question
   / air handler coils froze up - question #61
I will have to check out the line and maybe add a line from the pan.
I knew that when I bought my current place that the attic was a stupid place to put the air handler. Think about it, cold in the winter and hot in the summer. Sounds like dumb and dumber to me.
I told my builder, "No ductwork or air handler in the attic". People think the ducts are insulated so not a problem. Maybe an R value of 3 or 4 against extreme temperature differences (100 degrees or more)
QUOTE]
Could be worse.. I know people with hot water heaters in the attic!
As an update to this thread.. I usually have only been running the ac for a few hours before bed.. so not a real test to see if it was gonna freeze up again.. well last night I did tghe endurance test.. ran it from about 8pm thru about 7am.. worked fine...
soundguy
   / air handler coils froze up - question #63
soundguy[/quote]
Hey, I have my solar hot water tank in the attic! I did put 5 inches of Styrofoam insulation around it. I doubt if the heat leakage is significant. That does not bother me as much as water leaking potential. A 2 inch pan may not be enough.
as long as it's got a 2" drain it should be fine! :)
soundguy
   / air handler coils froze up - question #65
soundguy
It's a one inch. I think a 2 inch would require a hole so big it in the pan side that there would be nothing left of the pan side.
then thats a problem ;)
soundguy
CAT D8 (A58214)
CAT D8 (A58214)
2014 Ford Fusion Passenger Car, VIN # 1FA6P0H77E5377755 (A56859)
2014 Ford Fusion...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2016 Ford Expedition SUV (A56859)
2016 Ford...
2003 Komatsu WA380-6 Articulating Wheel Loader, S/N A54063, PIN# KMTWA095C36A54063, Turbo Diesel (A59076)
2003 Komatsu...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
