air handler coils froze up - question
   / air handler coils froze up - question #31
The best way to clean is wash to them from the inside out. I laugh:laughing: when I see guys spraying them from the outside in
That's the way I do it, and I was surprised a few years ago when a guy in that business said to just hose it off from the outside.:confused: I've wondered if I was wasting too much time and effort, but I've kept washing from inside out. Of course, I used my shop vac on the outside to get the cottonwood cotten off.
on mine, 4 nuts come off and my cover with fan will flip up and then I have access to the inside where I can blow air or water thru to the outside.
soundguy
   / air handler coils froze up - question #33
soundguy
soundguy
How is that ac unit working? Was the problem the filter? I couldn't go very long in FL without the AC.
I run the ac every night about 2 hrs before we go to bed then I kill it.
so far no repeat of the problem.
looks like I dodged a bullet on that one and it was just last years filter that killed me... I'm usually good about changing the filter with the electric bill.. last year at the end of summer I musta just left it in there since we don't require heat in the florida winter.. and forgot about it. This month was the first time we needed ac.. so.. was my fault..
soundguy
   / air handler coils froze up - question #35
soundguy
Good deal. Seems like my problems are never that easy.
don't feel bad.. I'm have a no-idle problem with my 98 dodge... runs great.. won't idle.. just dies at any pm under 600 .. IE.. keep yer foot ont he pedal a hair and she's fine.
looking at the throttle body inthe am, and vac lines, iac and map..
hopefully something will jump out at me..
soundguy
   / air handler coils froze up - question #37
soundguy
IAC motor was the problem when I saw this on wife's Dodge van.
   / air handler coils froze up - question #38
I am "blessed" with three units, one for my basement and 1st floor, one for the second floor and one for the bonus room over my garage. The upstairs unit was freezing. I figured it was low on freon but I put off calling for service until I could be home. It was not yet too hot so I would let it run about two hours to cool off the bedrooms then shut it down.
I wanting to see the service man go through his routine. Though I can pretty much do anything, I never charged up a system so I wanted to see that through.
Anyway, guess I did that a few times too many. After I had the unit charged up with freon, I happened to go to the basement for something. I saw some water damage under my dining room? With no water lines near, I went to the attic and took a closer look at the air handler up there.
Having only owned this place for two years, I had never been up there due to access being somewhat a pain. The house was fairly new so I only checked some circuits and did a once over myself when I bought it.
The unit does have a working drain but the pan underneath does not. It must have filled the pan with enough moisture to overflow. The overflow migrated down through the walls on both floors without bleeding through and staining the walls to boot.
I need to replace a few drop ceiling panels in the finished basement but that's all. All things considered, I got lucky there.
throttle body and port for iac was super dirty on mine.. just cleaned it yesterday.. dodge is back in action. I'm surprised it ran that dirty..
soundguy
   / air handler coils froze up - question #40
If you had a good tech. He/she would have inspected to insure that you had a switch added to the pan to shut down the A/C unit when the drain stopped up .Or in your case. no drain
2021 WANCO, INC LIGHT PLANT (A58216)
2021 WANCO, INC...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1702 (A58375)
1702 (A58375)
2013 Ford F-250 Crew Cab Pickup Truck (A56858)
2013 Ford F-250...
2018 Chevrolet Colorado Pickup Truck, VIN # 1GCHSBEA6J1312961 (A57453)
2018 Chevrolet...
Swict 72" Bucket (A57149)
Swict 72" Bucket...
