air handler coils froze up - question
   / air handler coils froze up - question #21
I guess my old Rheem didn't have a low pressure switch. The compressor just ran continuously when the coils were iced up and there was almost no refrigerant in the system. So of course, I had a new system installed a couple of weeks ago.
A low pressure switch can sometimes save your system
one of my VOM's also has the probe. Ilove it.
soundguy
   / air handler coils froze up - question #23
Cleaning the outside coils can make a huge difference in the efficiency of the unit.
Chuck
outside coils are clean.. just had them svcd last year when we had it apart to replace the cap on the cooling fan.
soundguy
   / air handler coils froze up - question #25
I still remember the time many years ago when I cleaned a lady's condenser coils and received a call from her 2 days later that her A/C was not cooling properly.
Upon inspection I found that the coils were completely covered with grass clippings. They mowed the grass while the unit was running and the discharge of the mower went right into the condenser so that unit went from squeaky clean to clogged in a few minutes.
I have also seen coils clog up in a few days when a nearby mimosa tree was shedding, so the only way you can tell if your coil is clean or not is by visual inspection.
   / air handler coils froze up - question #26
And I sure was glad when the folks next door had that big old cottonwood tree removed. Is anything worse than a cottonwood?
   / air handler coils froze up - question #27
SIL is in HVAC, so I get my service free, but after he showed me how easy it is to wash off the outside coils with the hose, I've done that job myself at the beginning of each summer. There's always some leaves, pine needles, cobwebs, grass clippings, or something in there. Takes a few minutes to spray it clean with the hose.
Chuck
As I said above.. outside coils are squeaky clean.. I had a seperate barrier built around my coils with plenty of breathing space around it back when the house was built.... no real way for debri to get to the coils.. especially not lawn clippings..
soundguy
   / air handler coils froze up - question #29
The best way to clean is wash to them from the inside out. I laugh:laughing: when I see guys spraying them from the outside in
   / air handler coils froze up - question #30
Yup. For me the most time consuming step is finding the right size nut driver to remove the cover. Actually, come to think of it, finding the right tool is the most time consuming part of any job I do. :ashamed:
Chuck
2104 (A58376)
2104 (A58376)
SDLanch SDLD25 Rubber Track Dumper (A57149)
SDLanch SDLD25...
2017 Ford F-150 Pickup Truck (A56858)
2017 Ford F-150...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
Mini Plate (A57149)
Mini Plate (A57149)
