Air filter for TS1610
/ Air filter for TS1610 #1
kodaknmi
I've been looking for an original replacement filter for my TS1610 and could not find one locally and am not about to spend the $65 I've seen quoted on the web.
I was inspired by a post by svcguy where he replaced his breather with a VW outfit and it looked good. Whilst looking for a filter I found a Fram CAK530 that had all the specs and measurements as my original but was about 2 inches shorter. However, it is readily available and best of all is only $8.55 and is also made by other manufactures, used by other tractors and should be around for a long time. So, I took a good look at my filter housing and filter and fabricated an adapter on my lathe that allows me to use the shorter filters with my factory breather housing. So now I have cheap readily available filters with the same 100CFM rating as the original OEM filters haven't changed anything on my tractor and I will save about $480+ over my next 8 filter changes. /forums/images/graemlins/cool.gif
/ Air filter for TS1610 #2
This is the type of post I like reading! While inexpensive, easily obtained parts make sense, many specialty tractor parts are prohibitive and can easily be adapted with substitutes using a bit of ingenuity. Two inches is not going to make a difference with clean filters. I think your adaptation of using the stock can is a better solution than my VW conversion, which required more modification. Keep up the good work!
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A65563)
2016 Hino 195h...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
Vermeer 605 Super F Round Baler (A65640)
Vermeer 605 Super...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2) 30'  42" High Pipe Racks (A62679)
2) 30' 42" High...
