Air Filter Bracket Problem
/ Air Filter Bracket Problem #1
dmartin88
Leesburg, Virginia
Kubota BX22, Bobcat 763H
Went out to use my BX22 yesterday, started the tractor to a very loud rattle like metal striking metal under the hood. Shut it down and opened the hood. Found that the top bracket holding the air filter in place had snapped where the top bracket meets the bottom portion of the bracket. A tie wrap got me back in business for the day, will have to price the part or decide to stay with the tie wrap. Guessing that the bolt bringing the two parts together was too tight and snapped in the cold weather last time I used the tractor.
Just wondering if anyone else ever had this part break, will call the dealer to get an estimate tomorrow.
/ Air Filter Bracket Problem #2
Check with your dealer about replacing it under warrantee. /forums/images/graemlins/grin.gif
Good point. If it was too tight, it would have been the dealer that did it as they did the 50 hour service. Will mention that when I call!
/ Air Filter Bracket Problem #4
I have a bx22 with about 140 hours, and mine broke at about 90 hours.
I repaired it myself, using a work clamp. Drilled a hole in the lower bracket so the work clamp would fit thru it, threaded the clamp thru and tightend it up.
I believe i have read oter threads on here reporting the bracket breaking.
/ Air Filter Bracket Problem #5
oops, that last post should have said "worm clamp" /forums/images/graemlins/blush.gif
/ Air Filter Bracket Problem #6
I believe there is a memo to all dealers to replace this part at no charge to the owner. Check with your dealer this should be a freebe /forums/images/graemlins/smile.gif. Many TBN owners have had this problem.
Ken
/ Air Filter Bracket Problem #7
Mine broke on my BX22 after a few short hours of use. There is a heavy duty bracket kit available to replace the strap . My dealer sent me one, no cost. The part number listed on the instruction sheet for the kit was K2561-98211. If you do a search for Air Cleaner Strap on BX, I posted the complete list of the kit's components in that thread. Try this link, my first attempt at adding a link, hopefully it works.
BX Air Cleaaner Strap
Dave...
/ Air Filter Bracket Problem #8
Mine too; dealer sent me the new one via UPS.
Thanks to all for the replies. Went to dealer today, I already have the new, improved, heavy duty version and this is what broke. They didn't have one in stock but they are getting me one at no charge. Did see the strap version and no surprise it broke but not sure the "improved" version has solved the problem. Good news is a new one is on the way.
/ Air Filter Bracket Problem #10
I replaced mine last fall. Big difference in the quality of the replacement part.
I can't believe they even put that cheapie on the machine after I looked at the new one.
I wonder how much the dealer charged Kubota for me replacing it myself though.
Tom
The concern I have is that the one that broke on my BX22 is the new, heavy duty version. Going to check tomorrow to see if the dealer found me a new one.
/ Air Filter Bracket Problem #12
I too have the same problem.But my selling dealer has been sold and the new owners closed the doors on that location.I spoke to the service man at the new dealership and he spoke to the warranty guy.They both said they do not know enough about Kubota, or any issuses to even comment on replacing my broken part.He suggested to buy the part and then look into the warranty coverage, and or bring the tractor in for them to look at and decide.
This new dealer is very well known in the area, but has no experience selling or servicing Kubotas.
Does anyone have a document from Kubota that shows this is covered under warranty?
Should I contact Kubota?
Thanks
I don't know the procedure for getting a warranty replacement from Kubota but I did receive my new bracket under warranty from the dealer. The replaced the strap portion which is where the break happened. They had all my purchase details and the only other question they asked was how many hours on the BX22 as they said they would need that when they filed their warranty claim. Sounds like you're getting a run around to me?
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
Landhonor SGB-11-72W, 72" Grapple Bucket  (A62679)
Landhonor...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
