Air Compressors
   / Air Compressors #41
I have a Thomas 2hp pancake for nailers and portable jobs and an Ingersol Rand T 30 12hp gas with 30 gal tank on one of my service trucks both are about 12 years old with no problems. I am humored when I see vacuums and compressors with 6 hp ratings that plug into a 120v 15 amp outlet, they must use some special physics laws I am unaware of.
Steve
   / Air Compressors #42
I have a kelloge compressor almost like the one in the picture model 331 and it is getting water in the oil . When I bought the compressor from a friend i had to put a new head gasket on the compressor . There is two small tubes running to the head was wondering what these tubes do . I made the gasket my self and didnt know if I did something wrong . The oil looks like milk . I know this isnt good. Please help. Thanks, Larry
Thats probably the unloader. It vents to the crankcase at low rpm on start and stop. Thats where most of the water comes from. Change oil more often. Or you could use a synthetic that water is not miscible in. The water would pool under the oil and you could suck it out occasionally.
larry
   / Air Compressors #43
In defense of oil-less compressors:
Of course sensible compressor sizing is important, and they're not as long-lived, but they have their place.
On a per-CFM basis they're expensive, but if you just need a little air, then the low buy-in cost is worthwhile.
One way they are great is if you need air without any hydrocarbons in it; for medical or food-handling uses. It's very simple: If you have oil in your compressor, then you will have oil in your air; if only a trace. With an oil-less compressor you don't need to consider HC removal when planning your filtration system.
Heat is the enemy: Compressing a gas increases its temperature; don't run higher pressures then necessary; it's also more efficient.
Many oil-less compressors have a run-in procedure. RTFM if you want to get the most out of it.
I see a few of you guys run nailers. Here's a tip:
I did some work for a construction company a couple of years back and when they needed to borrow a compressor of mine, we got to talking about their compressed air issues.
They usually kept their compressors wherever they first got power to the site and would run hoses wherever air was needed. They found that their nailers didn't run so well at the end of a long run. With the intermittent demand of their nailers the solution that worked for them was to put a remote air receiver on whatever level they were working on.
Any appliance that takes air in gulps and appears to be starved will be better served by having a secondary receiver nearby.
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2015 WESTERN STAR 4900EX (INOPERABLE) (A58214)
2015 WESTERN STAR...
large capacity skid steer bucket (A56857)
large capacity...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
