Air Compressors
   / Air Compressors #31
No offense taken. Thanks for the info. After reading your warning about their "Made in America" claims it makes a lot more sense to me that they dedicate a portion of their website to a defense of such claims. When I got mine I noticed that the pump was strikingly similar to the cheap Homier one I had before. I also noticed, however, that the rest of the thing is at least a step above the cheap compressors... Cooling fins on the tank feed tube, dual gauges, pre-installed quick connects, etc. I had just assumed from the beginning that "Made in America" meant what it means everywhere else... "Assembled in America". I've come to the same conclusion that radioman has...
I never based my decision on their Made in America claims. Like I mentioned before; my decision was based on warranty and duty cycle. I've personally been very happy with the purchase, and I'd buy from them again if I ever need another compressor.
Ive seen that page on their website before. It seems a little funny that they put it up. To quote shalkespere "thou dost protest too much". They hide behind the 60% domestic rule.
However those that have Eatons seem to like them, its just the companies policies i disagree with.
I try to support North American manufacture (preferably US and Canada) If we dont soon, there wont be much left. I wont give up on it just yet.
Im glad you like yours! It will likely serve you well.
   / Air Compressors #32
fwiw - I hooked up with a fiend of mine that was working in AT&T facilities. They were doing some hvac work there & part of the overall project was replacing the air compressors on the job. They had several 5 hp 3 ph units that they just scrapped because of their age (maybe 30-35 years old). It is my understanding that they cycle these out of all their facilities periodically. I managed to snag one of them. I replaced the 5 hp 3 ph motor with a 3 hp single phase and wired up my own low voltage controls. I have air piped to the garage now and the unit in my basement workshop. My only outlay was for the 3 hp motor. Everything else I had or scrounged. They are built like tanks (it is AT&T after all). It might pay to inquire at any local AT&T. . .
The unit:
and my low voltage control with monitoring light:
   / Air Compressors #33
I originally bought a Coleman 'Powermax' or whatever it is from Costco. Oiless, loud etc. but with a 26 gallon tank and 155 psi it runs the impact etc. just fine in the garage. Then I bought a little Black and Decker 135 psi oiless pancake for airing up dirtbike tires etc. at the shop as I was tired of dragging the Coleman back and forth (shop is at the other end of the property from the garage). It is actually pretty quiet and has a fan that continues to run after the compressor shuts off to help cool it down. I bought it at Target after Christmas. I have found that Target quickly marks down all the 'seasonal' tools etc. after the holidays and I got it for about $40 which was half of the full price.
Next I found an awesome Craigslist deal... an 80 gallon Curtis-Toldeo 5hp, 220v single phase, 175 psi dual stage oiled etc etc for only $500 :eek: Came out of a T-shirt printing shop and, while it is about 15 years old, looks brand new. That baby sits in my shop and can keep the tank full and shut off while I am sandblasting :) Biggest reason I got this was I have a lot of underground sprinkler runs that need to be blown out every fall. I knew my Coleman was going die a quick death if I kept using it for that. Also keeps up with my plasma cutter without breaking a sweat. I now use it as the 'mothership' for the little compressor... instead of running it I just 'top off' from the big compressor... should extend it's life greatly if I never turn it on ;) The little one is great for those tires 'just out of reach' but I could also plug it in most anywhere if I had to.
Now that I have lots of volume and pressure available I find myself using it a lot more to blow dust off things, run air tools I might not have bought otherwise etc. so I would probably buy the biggest one you can afford the first time around... otherwise you are going to end up with a compressor collection :D
   / Air Compressors #34
How to size an air compressor:
You will, on average, get 7-8 cfm @ 100-120 psi from a piston pump per true HP
The biggest real HP (not that Sandborn stuff) on 110v 20 amp circuits is roughly 1.5 HP. Maybe. 1 hp is more realistic.
Using a 220v circuit will get you up 5 hp, but you're gonna pay for it. Average 5 hp motor @ 220V is 28-30 amps. At 5 hp you'll get about 30 cfm @ 100 -120 psi.
So go with what it is you want to run, and see what you need, cfm wise.
One thing........ignore the tank size. Yes a bigger tank will give a better "cushion"........... for about 30 sec. Most tanks are there for removing pulsation/smoothing the air flow.
If your'e adventurous, the HF pumps don't look all that bad. They seem to be pretty well made. You may want to consider building one?
This is good, but your numbers are high on air delivery. I have a Kellogg American 2 stage intercooled unit. I think its about as good as you get in a reciprocating compressor. Its rated 20CFM delivery at 100psi on 5HP. --About 4CFM per HP at 100PSI. This is with the unit turning at 655rpm. On the same motor, by changing drive ratio, it will give 19cfm@125psi, 17.8@150, 17.2@175, 16.3@200, and 15.1@250. I have run the compressor at 700 RPM [top rating 750] and achieved a measured 20 CFM at 150 PSI using 6HP.
larry
   / Air Compressors #35
larry
As you can see from your pump, YMMV. Some, IR come to mind, are a bit more effcient than the Kellogg. The numbers I use are averages.
Heres an example of the difference. We have a Rogers Machinery royary vane unit from the early 80's. It's 100 hp and rated at 380 cfm @ 100 psi.
We bought a new IR machine thats also 100 hp but it's cfm rating is roughly 450 cfm @ 100 psi, a big difference. It just depends on pump design.
Looking at these numbers your calcs are right on for "hard" numbers. I'll jog mine down a bit.
   / Air Compressors #37
We used Quincy and Emglo PTO driven compressors mounted under our tractors to compress loads out of tank trailers. They would pressurize several loads of Sulfuric Acid [15.463 lb/gal] everyday five days a week. They were blue Emglo V-4's that used to cost around $600.00 just for the compressor.
We used a Sul-Air screw compressor w/ a 400 gal receiver tank and 2" distribution lines to maintain a high SCFM @ 140#psig for our shop. The diesel mechanic used to run a 1" drive impact to loosen the bearing cap bolts on 14L, series 60 Detroit Diesels that were tightened over 600 ft/lbs. Prior to the Sul-Air the old twin Ingersols made him do this by hand using a torque multiplier and long torque wrench. You do need to size the compressor tothe application.
   / Air Compressors #38
I have been using an oil-less 220 volt single head compressor xith a 50 liter tank for 15 years now. I'll grant you it's noisy but I generally use it outside (it has wheels). I use it for cleaning and unblocking everything, inflating tyres (cars, tractors, bicycles, even rubber boats), and mostly spray painting. Oilless compressors are preferred here for painting as you don't have to filter the oil out. Never had any problem with it, my only complaint is I sometimes don't get enough air, for instance when painting a large double door or a whole tractor, but that's only a small percentage of the time.
   / Air Compressors #39
Quincy makes some of the best. One of the large local machine shops replaced two IR's and a Speedaire with a single Quincy screw machine. I have a 5hp Quincy that I've used hard for 13 years. Would love to get one the Quincy 5hp screw machines because they include a cooler. For the money, the Speedaire equipment from Grainger isn't bad. IR also makes good compressors.
   / Air Compressors #40
The unit:
I have a kelloge compressor almost like the one in the picture model 331 and it is getting water in the oil . When I bought the compressor from a friend i had to put a new head gasket on the compressor . There is two small tubes running to the head was wondering what these tubes do . I made the gasket my self and didnt know if I did something wrong . The oil looks like milk . I know this isnt good. Please help. Thanks, Larry
2003 Big Tex 10PI...
2020 Steiner 450 Slope Mower (A57453)
2020 Steiner 450...
Caterpillar 259D (A57148)
Caterpillar 259D...
2016 Freightliner M2 106 Terex Hi-Ranger HRX55 55ft. Insulated Bucket Truck (A55973)
2016 Freightliner...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
Portable Restroom (A54865)
Portable Restroom...
