air compressor magnetic starter/relay single phase
   / air compressor magnetic starter/relay single phase #51
Update. Measured again, 240v current draw just turning alternator is 5 amps, with field current applied to alternator 11 amps, welding at 110 amps, 27 amps. Would be under 5 amps not running anything.
   / air compressor magnetic starter/relay single phase #52
All my 3 phase is run via a rotary converter made from an old 3 phase motor...
No pony motor... simply give wind rope around the idler and give it a pull as I power it...
25 years and it has been working...
   / air compressor magnetic starter/relay single phase #53
Keeping it simple has advantages. Not much can go wrong.
Good luck to the OP with his air compressor. We kind of got off topic.
2019 PRINOTH PANTHER T14R CRAWLER (A51242)
2019 PRINOTH...
Poly Round Bale Ring (A50515)
Poly Round Bale...
John Deere 1025R Tractor (A50514)
John Deere 1025R...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2015 KUBOTA M5660SU 4X4 FARM TRACTOR (A51243)
2015 KUBOTA...
