air compressor magnetic starter/relay single phase
   / air compressor magnetic starter/relay single phase #51
Update. Measured again, 240v current draw just turning alternator is 5 amps, with field current applied to alternator 11 amps, welding at 110 amps, 27 amps. Would be under 5 amps not running anything.
   / air compressor magnetic starter/relay single phase #52
All my 3 phase is run via a rotary converter made from an old 3 phase motor...
No pony motor... simply give wind rope around the idler and give it a pull as I power it...
25 years and it has been working...
   / air compressor magnetic starter/relay single phase #53
Keeping it simple has advantages. Not much can go wrong.
Good luck to the OP with his air compressor. We kind of got off topic.
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
2014 MACK CXU613 (A50854)
2014 MACK CXU613...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
Hydraulic Hose Reel (A49461)
Hydraulic Hose...
