Air Comoressor on Diesel
   / Air Comoressor on Diesel #11
Once you determine the drive pulley size you have to install an unloader valve of some sort as the engine will not want to start with pressure in the lines.
At the tank you want a check valve and between that check valve and motor a pressure relief so as to not overload the tank.
For a cheap easy solution a slow leak, LOL, B4 the check valve will bleed off pressure allowing unloaded start up.
(even a leaky fitting can do) and with the large volume of air generated performance would not suffer.
You said aviation, so I suggest even hydraulic relief valves and PRV will do the job if you have some 'odds and sods' in your tool box.
(a also aviation guy and have used lots of odds and sods for air, note hydraulics generally are much higher pressures so safe)
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
Zero Turn Mower (A59231)
Zero Turn Mower...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
