Agra Fab Leaf sucker
/ Agra Fab Leaf sucker #1
JeffreyOwens
Anderson, AL
Cub Cadet 3240, Kubota M9000
I have an Agra Fab Leaf sucker (I know that's not the right name just cant remember). Anyway the problem is that when running the exhaust turns cherry red it will also back fire thru the carburetor when turning off. Is this a timing issue or what else could it be. It is a Briggs & Stratton engine. Thanks in advance for any help.
/ Agra Fab Leaf sucker #2
Running lean usually makes them run hotter.
Is there a throttle on it to idle it down to cool itself for a while, before shutting it off..?? I've seen a few people shut engines down hot, from WOT, and do this. Then, in a few years wonder why they don't run right, or at all.
I'd imagine it is so hot on shutdown, if the exhaust was cherry red, it's igniting fuel vapor brought in, when dieing down, simply from the heat alone. Doubt it has a fuel cut off solenoid, so it keeps sucking fuel in. All you are doing is killing the spark, not fuel, into the cylinder, and popping back through the intake valve.
2006 Ford F-450 Crew Cab 9ft. Stakebody Flatbed Truck (A66736)
2006 Ford F-450...
2016 John Deere 6145M (A64911)
2016 John Deere...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
2017 MAC Half Round T/A End Dump Trailer (A68183)
2017 MAC Half...
BX23 TLB 10k OBO
BX23 TLB 10k OBO
2017 FREIGHTLINER CASCADIA 125 6X4 T/A  SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
