"AGM Car" batteries for less used tractors?
   / "AGM Car" batteries for less used tractors? #71
I am getting over 10 years on AGM batteries in tractors, up to 15 years at the most. I do pull them in the off season and bench them on a maintainer.
I don't pull my batteries but keep fully charged a leave on a 1 amp trickle charger quite a bit. I use the NOCO 1 amp smart charger for $30 on Amazon. After doing that I noted my batteries were lasting far longer.
   / "AGM Car" batteries for less used tractors? #72
I have 3 of the NOCO chargers (two 2 amp and one 5 amp) and one Optima charger that I rotate around. Amazing how long the batteries are lasting.
   / "AGM Car" batteries for less used tractors? #73
Good point. I wanted to start a thread that everyone with equipment should own at least several of the $30, one amp NOCO smart chargers. You don't have to leave them on all year around but I do rotate over winter and do put on first thing in the spring for several days. I also have a 3 and five amp charger.
I posted before but I have had many batteries well over 10 years old. These smart chargers pay for themselves.
   / "AGM Car" batteries for less used tractors? #74
I have 2 Opimate chargers (which I think are the best smart chargers), and at least 10 of cheaper smart chargers, 1 LifePo1 chargers for lithium batteries, one 60A booster (old style, not smart) and one 200A booster (old style not smart).
Experience tells me that a guy needs at least one old style booster charger to charge up batteries that are will work, but are discharged because smart chargers cannot charge a discharged battery.
   / "AGM Car" batteries for less used tractors? #75
Minnesota that is one way to handle it and it works if you don’t forget it and leave it on all week. I have been told that you can take a nine volt battery and tie it in and trick the smart charger into doing its job. I usually put a set of jumper cables in with the little smart charger. Now I have never tried these chargers you like, but if they are good as a no co they are something else. Have a good weekend sir
   / "AGM Car" batteries for less used tractors? #76
I thought there was some way to override a smart charger to get it to charge a battery that was fully discharged. I'm sure I read this somewhere but not sure where.
   / "AGM Car" batteries for less used tractors? #77
Look up "force" mode in the instructions.
For the NOCO Genius 1,the complete manual is online.
Too bad not in the box!
   / "AGM Car" batteries for less used tractors? #78
I have a 1/2" Milwaukee impact driver that if I forget about leaving a M18 battery on it, it'll flatline the battery and then none of the Milwaukee chargers will charge it up. So I use two razer blades to jump two M18 batteries together to boost the flat battery up to enough for the charger to recognize the battery, or I use the blades with a bench top power generator to do the same.
Bench voltage generators are a godsend for doing bench testing of vehicle junk. Here I'm playing with some whip lights.
   / "AGM Car" batteries for less used tractors? #79
I really do not RFM much because I'll forget what it said, anyway.
   / "AGM Car" batteries for less used tractors? #80
The trick that I have heard is to parallel a good battery with the dead battery with a set of jumper cables, then connect the smart charger. The good battery will keep the voltage high enough that the smart charger activates. I would take the good battery off as soon as the dead battery has a charge to it so the charger can focus on that battery.
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2021 DEERE 333G LOT NUMBER 198 (A53084)
2021 DEERE 333G...
New/Unused 10ft Workbench with 15 Drawers (A51573)
New/Unused 10ft...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
