Tires AG tires on backwards
   / AG tires on backwards #41
My neighbor reverses his front tires in the winter to get better traction when blowing snow.
Makes sense when you think about it.
Yep, especially if the blower is in the back and going in reverse. :)
   / AG tires on backwards #43
When a tractor wheel is rotated outward the lugs are loosened from the slide rail on the rim and the clutch is engaged while applying the brake on the opposite side to be rotated. Most CUTS don't have this capability.
   / AG tires on backwards #44
You are referencing power adjust wheels... That is for adjusting track width, important for row crop. Having nothing to do with tread pattern direction.
as mentioned earlier....Turf tires are always going the right direction...
   / AG tires on backwards #45
My head is starting to hurt...I've decided to monitor my hour meter and drive forward for an hour and then back up for an hour...go back and forth like this all of the time and it shouldn't be a concern...plus, I'll probably get even tire wear! HA! HA! GENIUS!!!
   / AG tires on backwards #46
Komatsu Pc200lc Excavator (A50514)
Komatsu Pc200lc...
UNUSED AGT NT18K EXCAVATOR (A51243)
UNUSED AGT NT18K...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
2016 Laymor SM300 Towable Ride-On Rotating Sweeper (A50322)
2016 Laymor SM300...
