Ag exemption
/ Ag exemption #41
/ Ag exemption
They count your driveway and the land the house sits on, I loose 1 acre for the homestead. Tax exempt for things like tractors you fill out a form at the dealer, for other stuff you need get tax exempt certificate and file annually, on your taxes you run it like any other business, there used to be a special class number for timber farming but now it is form F and fill in Timber farm.
I did find this out today, as you said when I build they will associate 1 acre of land as no longer greenbelt ( so you homestead instead that single acre ) but the rest is still at a reduced rate assuming you are still practicing agriculture which I have every intention of doing.
I appreciate most of the comments. Thanks
/ Ag exemption #44
Some products that you purchase are dependent on their end use. For example, if I buy some steel beams, if they are for a new building, it is not exempt, if it is for maintenance or safety of existing structures, then it is exempt from sales tax. Check with your tax officials.
2003 McCormick XTX 185 XtraSpeed Tractor (A63688)
2003 McCormick XTX...
1000 GALLON ELEPTICAL NURSE TANK TRAILER (A64276)
1000 GALLON...
(1) UNUSED 420/75R34 TIRE W/ 8 LUG RIM (A64280)
(1) UNUSED...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
