After market cutting edge?
/ After market cutting edge? #1
Chainsaw.
Yanmar YM1500 & YM2000D
Hey all. I have a no name FEL with a little bitty bucket on it. I'm wondering if anyone has found a good source for a hardened cutting edge for a 48" bucket. I would like a reversible one, held one by carriage bolts. The mild steel edge....isn't gonna cut it. :cautious:
/ After market cutting edge? #3
Here's the ticket, and it's been shipping within 2 weeks here lately!
Travis
Thanks Smokey!!
/ After market cutting edge? #5
This probably a little late, but just in case. Tractor supply has a line of boron steel bucket edges. Very hard, very strong, great for bolting on. They are a significantly stronger steel compared to Titan, who make great attachments. Welding is probably not for novices.
All the best,
Peter
/ After market cutting edge? #6
There are a number of reviews of cutting edges for front end loaders on YouTube. I am favoring the Wicked Toothbar by Everything Attachments, which Ted posted above. These appear to hold up well and they are custom made for your tractor based upon your measurements. I hope to order one for my tractor this week.
/ After market cutting edge? #7
Chainsaw, you mentioned carriage bolts - all the edges I've seen/used have been held on with PLOW bolts - look sorta similar to carriage bolts, but end up being completely flat with the surrounding surface - here's what plow bolts look like
If your "itty-bitty" bucket edge really IS carriage bolts, just ignore me :oops: ... Steve
/ After market cutting edge? #8
The thing about a bolt-on cutting edge held on with plow bolts (basically what you'd find on most rear angle blades or box blades) is that it has to bolt onto something fairly strong to keep the things you run into from 'peeling up' or wedging into the front edge of the '
actual bucket'. So unless you are bolting THROUGH the existing cutting edge, it's a semi-bad idea to just bolt a real cutting edge to some 1/8" sheet and go start prying on things. It will probably peel open the corners of the bucket and the front edge of the bucket will be a wavy mess after a while.
I have a 48" bucket that the factory cutting edge was only stitch welded to (not fully seam welded all the way across) and i have wedged things pretty hard into that gap where it is not welded.
So i'd say either weld on your replacement and just buy it thick/strong enough that you'll never run out of material to 'redress', or bolt it THROUGH whatever cutting edge is on there now and just deal with how it hangs off the bottom a bit funny.
/ After market cutting edge? #9
I had to replace the original cutting edge on my BX2230 a while back. I bought a new factory piece, and a replaceable edge for a later BX, clamped them together, marked the holes on my original type edge and drilled it so I could bolt the replaceable edge to it. Had the replacement edge welded on and then bolted the extra edge to the bottom of it. Trimmed the attaching bolts off flush with the nuts and it has worked like a charme ever since.
Steve. I'm sure you are correct. I've replaced countless dozer, motor grader, scraper etc blades, so I'm familiar with the bolts you speak of, just didnt know what they are called. Thanks!
/ After market cutting edge? #11
No prob; I've always been curious about anything I don't know about, and a really good memory tends to keep that info available (sometimes :=) - but looking back, probably the LONGEST "delay" in learning I'm aware of was about 47 YEARS :oops:
I have a few gear pullers, some I've had since I was 19 - one of those had these weird threads on the pusher bolt which would only thread into the spreader in ONE direction - a closer look (back then) showed me why - one side of the threads was at 90 degrees to the bolt axis, the OTHER side was where ALL the angle of threads happened - didn't take too long to understand that made it stronger on the "push", where it was needed...
Slow forward to just before I retired (almost 10 years ago) - I was running an ll man rotating maintenance crew (including me) and FINALLY got around to asking one of my machinists (on his last week before retiring, and irritable at having to wait) if that thread profile had a name - he looked at me like I was an idiot, and said "those are Buttress threads - I thought you instrumentation types "knew everything" -
I've always been sort of a smart-azz, so of course I replied, "NOW I do, thanks..."
That got a laugh out of him, so that day we BOTH won... Steve
INOP/NON - RUNNING 1997 Procraft Fish/Ski Boat (A65579)
INOP/NON - RUNNING...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2 Row Cultivator (A64047)
2 Row Cultivator...
2021 Kenworth T880 Tandem Dump Truck, VIN # 1NKZL40X6MJ464380 (A65563)
2021 Kenworth T880...
2017 Scag 72" Zero Turn Mower (A64194)
2017 Scag 72" Zero...
Auger Cart (A65640)
Auger Cart (A65640)
