Aerator weight ??
/ Aerator weight ?? #1
bx2670
Pilot Mountain N.c.
2013 Bx 2670
I have a Bx 2360 and was gonna get a 48" cat 1 aerator that weighs 240 lbs empty.You can fill drum with liquid another 238 lbs if you want, don't think I would need to add liquid but my ?? is would I need to add weight to front end with the weight of the aerator by itself??? Don't want to be doing wheelies in my yard.:D:laughing:
/ Aerator weight ?? #2
Depending on your soil type you most likely WILL need to add weight to the aerator. I have a 72" that weighs 525 dry and i add an additional 500lbs to it making a total of around 1k, it only drives about 2-1/2 inches into my heavy clay soil. I had to add 250 lbs of front weight as the fronts got light on steep hills. If your land is fairly flat i would think you should be ok. Hilly land will be questionable.
/ Aerator weight ?? #3
i have the same set up on a bx2200 its a load. not sure the weight
but it does a good job have a loader so it helps balance it out.
it has fluid not sure how much. dad has a hilly yard when i take it
to his house i have to use low. start turning about 20 foot before you need to.
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2020 Ford Explorer SUV (A61574)
2020 Ford Explorer...
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
APPROX(15) DIAMOND PATTERN PLASTIC PROTECTION MATS (A64281)
APPROX(15) DIAMOND...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
