Aerator weight ??
/ Aerator weight ?? #1
bx2670
Pilot Mountain N.c.
2013 Bx 2670
I have a Bx 2360 and was gonna get a 48" cat 1 aerator that weighs 240 lbs empty.You can fill drum with liquid another 238 lbs if you want, don't think I would need to add liquid but my ?? is would I need to add weight to front end with the weight of the aerator by itself??? Don't want to be doing wheelies in my yard.:D:laughing:
/ Aerator weight ?? #2
Depending on your soil type you most likely WILL need to add weight to the aerator. I have a 72" that weighs 525 dry and i add an additional 500lbs to it making a total of around 1k, it only drives about 2-1/2 inches into my heavy clay soil. I had to add 250 lbs of front weight as the fronts got light on steep hills. If your land is fairly flat i would think you should be ok. Hilly land will be questionable.
/ Aerator weight ?? #3
i have the same set up on a bx2200 its a load. not sure the weight
but it does a good job have a loader so it helps balance it out.
it has fluid not sure how much. dad has a hilly yard when i take it
to his house i have to use low. start turning about 20 foot before you need to.
UNUSED SDLANCH RIDE ON SKID STEER (A64280)
UNUSED SDLANCH...
UNUSED SDLANCH SDLC2533FT 25'X33' METAL SHED (A64281)
UNUSED SDLANCH...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
HLA Attachments Loader Forks (A64119)
HLA Attachments...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
