Advise on winch for tractor
/ Advise on winch for tractor #21
Mike,
I agree that winches never seem to be on the right end when needed. Portable winches are great too. The winch I was planning to put on my tractor has been serving portable duty on my trailer and also on the loader for a couple of projects. I still plan on mounting it at some point. For me when I am on the land I bought there is no one around to help and I would like to have the winch to get me out of the mud if needed or worse yet the pond. Some creativity with a snatch block will hopefully work. Someone mentioned the current draw from electric winches. They do have a huge current draw, but the run time is usually not that long and you may be suprised at how long you can run one without draining a battery. Hydraulic or PTO would be much better if you plan on having long pulls. Usually to get unstuck, the pull is quite short. Just my 2 cents.
Russ
/ Advise on winch for tractor #22
Just to add i know Ramsey makes winches with permanant magnets. These draw about 220 amps vs the wound winches (like Warn) that draw about 450 amps. I think our old 4020's had 2 batteries, maybe a 24v system, don't exactly recall. The plus on the wound motors is they can pull longer without overheating. Permanants heat up faster and the heat will damage the motor. I have Ramseys for my truck. It was a cheaper winch and I really don't care if it takes me 10 minutes or 30 to get out. IE I never will cross a rising river. I made a multi mount set up for my truck and both my ATV's have a 2500 winch with a MM setup. So far I've only used the winch to pull the boat out of the river. Here is a little info on that..
Rancher Winch
/ Advise on winch for tractor #23
I wandered into a hydraulic shop here, was talking with the manager, when one of the guys from the back hollared at him, saying he had a problem. I went to the back with him, saw the problem, thought of a cure, and told the manager. He told me to give him a price on building them. I did, as a "cash" price. He Ok'd the deal, but before I delivered, he called, saying he needed twice the order, for another shop. I built two sets, expecting cash for both. Didn't happen. He asked me if there was anything in the shop I wanted, instead of cash. I noticed a Pro 9000 winch sitting on the shelf, and told him I wouldn't mind a nice winch for my junk truck. He pulled out a catalog and told me to pick out the one I wanted. 12K Ramsey, with all the options, including Chrome.
Never did mount that winch, it was too pretty.
David from jax
/ Advise on winch for tractor #24
RobJ,
Thanks for the good info. I do not know what type of motor is on the winch I have. The winch came off an old light duty wrecker. Without digging it out, I believe it is a Koenig. It has worked well for what I have used it for. I still hope to mount it at some point. I have thought of making a receiver type mount. Thanks again for the info.
Russ
/ Advise on winch for tractor #25
If you have a koenig hyd you have a treasure. I have been using them for over 20 yrs for my application and haven't had any problems.
Thing is about having a winch mounted on the tractor is that you won't bury the rig trying to get it out. It will be a simple matter of hooking up to something before it is buried to the frame.
I have one mounted permently in my loader frame. I use it more than I could possibly have imagined. Anytime I am loading an emplement, picking trees, you name it, it is right there. Having a variable length cable on the front of the rig is great.
/ Advise on winch for tractor #26
Rdbrumfield,
Mine is electric. Hydraulic would have been nice, but the price was right. I was thinking I would mount it on a hood/ grill guard on the front of the tractor, for those occasions I get in the mud. Like you said, I figured I could get it out before it got buried too bad. I am typically the only one around when I am working on the land I bought and hate the idea of sinking my tractor.
Take care,
Russ
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2021 CATERPILLAR 305E2 CR EXCAVATOR (A64279)
2021 CATERPILLAR...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2019 Ford Fiesta SE Hatchback (A61574)
2019 Ford Fiesta...
3142 (A63117)
3142 (A63117)
