Buying Advice Advice requested
/ Advice requested #1
bobferdon
I put up a post the other day about an odd noise on my 1641. This is a follow up.
I went to check the fluid in the hydro and it appears the last couple of inches of the dipstick are gone. There is a clean break.
Possibly the noise I hear when I first start off is the broken piece inside the hydrostatic trans?
Should I be pulling this apart looking for it?
This might be out of my league.
Thanks...
/ Advice requested #2
Well Bob one thing you can try is to drain the hydro and check the strainer if it has one then blow some compressed air in there to see if you can blow that piece out. It's not going to be easy.
Start by jacking up both rear wheels to see if you can hand manipulate the piece out by rotating the tires...use a hooked hanger that kind of thing. Good luck and report back.
/ Advice requested #3
Bob, I would try the easiest thing first. Get a flexible magnet and poke around in the fill hole and see if you can catch anything. Worth a try.
Bob B.
/ Advice requested
that was the first thing I tried.... no luck
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
2015 Chevrolet Silverado 3500 Pickup Truck, VIN # 1GB4KZC88FF627993 (A65563)
2015 Chevrolet...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
