Buying Advice Advice requested
/ Advice requested #1
bobferdon
I put up a post the other day about an odd noise on my 1641. This is a follow up.
I went to check the fluid in the hydro and it appears the last couple of inches of the dipstick are gone. There is a clean break.
Possibly the noise I hear when I first start off is the broken piece inside the hydrostatic trans?
Should I be pulling this apart looking for it?
This might be out of my league.
Thanks...
/ Advice requested #2
Well Bob one thing you can try is to drain the hydro and check the strainer if it has one then blow some compressed air in there to see if you can blow that piece out. It's not going to be easy.
Start by jacking up both rear wheels to see if you can hand manipulate the piece out by rotating the tires...use a hooked hanger that kind of thing. Good luck and report back.
/ Advice requested #3
Bob, I would try the easiest thing first. Get a flexible magnet and poke around in the fill hole and see if you can catch anything. Worth a try.
Bob B.
/ Advice requested
that was the first thing I tried.... no luck
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
Kubota KX080-4 (A64126)
Kubota KX080-4...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
