Advice on Welding/Warping of this Assembly
   / Advice on Welding/Warping of this Assembly
To close the loop. First I checked the 2x2 beam for straightness. One side was 3/32 bowed. I tacked the five brackets to the high side, and that straightened the bow. Then I clamped the beam to a 4x4x3/16 tube, with a piece of 1/8 strap under the bracket to be welded. Welded the middle one first, checked for straight, it was perfect. Did the other brackets the same way. Ended up with no discernible warp at all. I decided to leave off the gussets, would be overkill for strength and just put a lot of unnecessary heat into the beam. Again many thanks for much needed advice.
2019 Ford F-550 XL Crew Cab Forestry Chipper Truck (A49461)
2019 Ford F-550 XL...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A49461)
2019 Fontaine...
3in Poly Pipe (A49461)
2022 Adams CLC-1013 Conveyor - New (A51039)
2022 Adams...
2013 John Deere 824K (A51039)
2013 John Deere...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
