advice on welding rods
/ advice on welding rods #41
When I worked for Hobart Brothers (Filler Metal Division) years ago, I was certified in stick, tig, mig, and sub-arc welding. I worked in the R&D lab as a test welder. Most of my welding jobs were "Audit" welding for General Dynamics (Lima Tank) and Newport News (Shipyard). I had to weld up a pair of 3/4" thick x 14" long steel plates (A36, AH36 and E series steels) and these plates had to pass X-ray first, then they were machined for Sharpy V-Notch impact tests, and tensile tests.
X-ray was toughest to pass on 7018 AC rods. We were allowed only 3 specs of porosity in the entire 14" weldment. Spots could not be larger than 1/8" in diameter. The easiest ones were the 7018DC McKay electrodes in 1/8". 60xx series rods in AC were the easiest for me for out-of-position.
Most of the time the 7018 series rods wouldn't reach failure on the tensile test until about 78,000 PSI. V-Notch impact tests were performed after a bath in liquid Nitrogen and they always passed specs....never had one fail that I can recall.
Obviously the wires both flux and gas shielded were easier than stick electrodes, to weld with and pass the x-ray tests. Your starts and stops have to be ground out in the weldment to pass x-ray most of the time.
If you failed a plate on x-ray, you had to weld 2 more and submit both for x-ray. If either one of those failed, you had to weld and pass 4 plates.
Well I have the new spring hangers welded on, the spring shackles were set 1 inch wider than the springs and when the unit was set down the travel was 3/4, this should give plenty of smoothe travel for springs. Got the gusset plates welded over the splices and top and bottom flanges, hooked it up to the truck and tongue weight is 350 pounds, pulled nice for the 3 blocks where I can finish the project such as hull supports and front support, thinking I should use checker plate at the front to box in the frames giving some storage. In both pictures the boat looks small compared to the truck.
UNUSED MGY-50KW FUEL HEATER (A62131)
UNUSED MGY-50KW...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
2013 ISUZU NQR 4X2 REFRIGERATED BOX (A59909)
2013 ISUZU NQR 4X2...
John Deere 2155 (A62177)
John Deere 2155...
10 TON HYD JACK (A62131)
10 TON HYD JACK...
UNUSED WOLVERINE JMR-22-8.5G SUSPENDED RIPPER (A62131)
UNUSED WOLVERINE...
