Advice on replacing JD4720
/ Advice on replacing JD4720 #1
Edmonton
John Deere 4720
I just sold my JD 4720 tractor with cx400 loader and 448 backhoe which i owned for 16 years. See pic. It has been a great tractor, but i need to replace it. I have narrowed my decision to three models. JD4066, kubota L47 and the M62. I know they are not exactly the same machines, but i used to be a chicken farmer with a large acreage. i no longer have chickens, but still have the acreage and use my machine more as a tool as oppose to a tractor. i plan to do small foundations, landscaping, forklift work and dirt work in the future. Any advice on which would be the better choice. I may need to haul the machine around to all my projects. i would love to hear from a long time JD guy who went orange. I know the JD 4066 would be a great tractor, but a think the Kubota L47 or M62 would be better for certain tasks.
/ Advice on replacing JD4720 #2
If your just useing it for landscape work and construction why don't you just buy a machine that was ment to do that kind of work a JD 310 ? Way out perform any machines you listed for the same money if you buy used.🍻
/ Advice on replacing JD4720 #4
If you have a Yanmar dealer near by check out this tractor:
willy
willy
The only issue is I dont know which dealer would sell it, i also fear the resale value would not be as good as a JD. I bought the JD 4720 new for 46,500 16 years ago and sold it this week for 43,000. Its hard to beat the resale value on a kubota or JD.
/ Advice on replacing JD4720 #6
Used tractor prices are climbing, in some cases its
better to purchase a new tractor as they want almost
as much for a used one.
I see you live in the land of no place???
willy
/ Advice on replacing JD4720 #8
Heard a lot of stories about JD plastic tractors
not good and JD & Kubota make their tractors
so aftermarket equipment don't fit so I have read.
And they change this every few years bummer!!!
I would suggest the you check out the LS 225 or
above and the Yanmar tractors if you can.
willy
/ Advice on replacing JD4720 #10
I have a JD 4720 with a 448 backhoe. When it broke in half I replaced it with a Kubota M62. Not really in the same class. Great machine for what I am doing. So, I have a 448 for sale.
/ Advice on replacing JD4720 #11
Those 4720"s tend to get hammered pretty good. That's a little too much power on too small off a machine. I am glad I went for the 4120 back in 2005 when a guy could still get an American made engine in a 43 hp tractor. I have a bit over 1000 hrs on it now and it is as tight as it was when new.
These days, I think you got to settle for Asian or European engines in tractors of that size. That wouldn't have gone over well for me back in 2005, when a couple of my uncles who fought those folks were still living.
/ Advice on replacing JD4720 #12
I have the older than the M62 ( and slightly smaller ) Kubota L48 TLB.
The M62 would seem to fit your desires perfectly!
It is a built from the ground up, as a specific medium duty earth moving machine.
Nothing else in the size/weight group compares!
Be absolutely certain to get a hydraulic thumb!
/ Advice on replacing JD4720 #13
L47 and even more so M62 outclass anything else in that size. A regular compact tractor with a hoe isn’t even in the same class.
/ Advice on replacing JD4720 #14
They are both great machines, but the L47 has a 10' dig depth, while the M62 has 14' dig depth.
4 more feet of dig depth (hoe reach) is a BIG deal!
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
John Deere HX15 (A64126)
John Deere HX15...
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
