Buying Advice Advice on Bobcat CT225 2010
   / Advice on Bobcat CT225 2010 #1
SJay
Tri City Area, MI
Bobcat CT225 Tractor, John Deere 4x2 Gator, Husqvarna Zero Turn, John Deere Buck 650 ATV
I am looking at a Bobcat CT225 with loader. They are asking $9,850.00 for it, has 415 hours on it, was used at a Bobcat dealership (rental and yard maintance). It has the hydro pedal that does not want to return to the center position. I read the thread on that problem. Did any one find a solution other than a new HST? Any long term problem if the pedal isn't corrected? Is the pricing good on the tractor? They actual said they are going to fix the HST pedal problem. :) They are going to let me demo it for a few days next week. Anything else to look for? Any longer term owners want to chime in:thumbsup:
Thanks
   / Advice on Bobcat CT225 2010 #2
The fix for the non returning pedal, is to tap the reverse pedal....
   / Advice on Bobcat CT225 2010 #3
I have a ct225. The problem seems to come and go. when I notice it, I make sure it is lubricated and work it a while. Fine after that. i would not worry about it. I have 1300 hours on mine.
   / Advice on Bobcat CT225 2010 #4
It may be a simple lubrication issue, or weak springs. I doubt if it is anything more serious. Kubotas have one or more grease zerks on the HST pedal shafts.
   / Advice on Bobcat CT225 2010 #5
I love my CT 225 best tractor I ever had and i have had many. Price sounds fantastic if the tractors in decent shape and they fix or warranty any issues with that Hydro pedal. I have not had any of the Hydro problems as of yet and I have a little over 200 hours.
Just for clarity - the CT225 is a 2010 Model
   / Advice on Bobcat CT225 2010 #7
The HST pedal is an easy minor fix. The price is very good. As long as it's not that beat up I'd say it's a good deal. Equivalent to the Kioti CK25, great little tractor. Year of manufacture isn't really a concern like with cars, hours are what matter.
   / Advice on Bobcat CT225 2010 #8
Mine's a 2011. It has never completely returned to center even since new. I just got used to bringing it to neutral with my heel or toe. It's not a big deal.
..now if you're saying it stays at whatever position you leave it, that would concern me.... mine will come 90% of the way back to neutral and will creep.
I will really test out the HST pedal when they drop it off for the demo - anything else to look for? Thanks for the help.
   / Advice on Bobcat CT225 2010 #10
Corrosion around the battery terminals and battery tray.
All the filters should have been changed on the hydro ( 2 )
This unit might have the previous generation of loader on it, which had some issues with cracking in the cross member between the loader arms.
Other than that...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
New 40ft High Cube 6 Door Container (A59000)
New 40ft High Cube...
2012 DIAMOND C 40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
Dayton 32965 80-Gallon Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
LOT: (3) Shelves of Parts, Filters, Oil, Antifreeze (CONTENTS ONLY - ALL APPEAR TO BE UNOPENED) (A59076)
LOT: (3) Shelves...
