Buying Advice Advice on Bobcat CT225 2010
   / Advice on Bobcat CT225 2010 #11
Corrosion around the battery terminals and battery tray.
All the filters should have been changed on the hydro ( 2 )
This unit might have the previous generation of loader on it, which had some issues with cracking in the cross member between the loader arms.
Other than that...
I think the loader on the Bobcats is not Kioti, maybe Woods, so it would not have the cracking issue that the KL120 and 130 did.
   / Advice on Bobcat CT225 2010 #12
The loader on the early bobcat tractors was made by rhino. They changed from rhino to their own bobcat made loader sometime around 2010/2011. The older style loader has the curved loader arms where as the newer loader has the angled loader arms I do not know why they changed. I forgot to mention before that I did have problems with my stock bobcat brand battery. It would leak if I used the tractor on a very steep incline. This was evident from new so I replaced it with a gel type battery. I also heard of two other things on some of the early tractors. Some had a fuel injection or fuel solenoid problem can't remember exactly And heard of a couple of problems with a Hydro cooler. It's pretty much the same tractor as a Kioti CK 27 so you could research those as well I think that's where I heard of the later of the two problems I mentioned. All machines are going to have their specific issues but I think overall The bobcat tractors are top notch.
   / Advice on Bobcat CT225 2010 #13
The only major issue I know of with the Kioti CKs is the loader problem, which is almost ancient history now, and the IP issue through 2008, neither are an issue here I believe. Of course, the usual stuff with any used tractor still applies.
I know this is and old thread - I did buy the CT225 - thanks for all the help - and I love the tractor (1st one):cool2:
   / Advice on Bobcat CT225 2010 #15
Thanks for the update. I love mine to their incredible machines.
2003 KOBELCO SK235SRLC EXCAVATOR (A57880)
2003 KOBELCO...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2008 Chevrolet Express Box Truck (A56858)
2008 Chevrolet...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2019 Harley Davidson Electraglide (A55973)
2019 Harley...
