Buying Advice Advice on Bobcat CT225 2010
/ Advice on Bobcat CT225 2010 #1
SJay
Tri City Area, MI
Bobcat CT225 Tractor, John Deere 4x2 Gator, Husqvarna Zero Turn, John Deere Buck 650 ATV
I am looking at a Bobcat CT225 with loader. They are asking $9,850.00 for it, has 415 hours on it, was used at a Bobcat dealership (rental and yard maintance). It has the hydro pedal that does not want to return to the center position. I read the thread on that problem. Did any one find a solution other than a new HST? Any long term problem if the pedal isn't corrected? Is the pricing good on the tractor? They actual said they are going to fix the HST pedal problem. :) They are going to let me demo it for a few days next week. Anything else to look for? Any longer term owners want to chime in:thumbsup:
Thanks
/ Advice on Bobcat CT225 2010 #2
The fix for the non returning pedal, is to tap the reverse pedal....
/ Advice on Bobcat CT225 2010 #3
I have a ct225. The problem seems to come and go. when I notice it, I make sure it is lubricated and work it a while. Fine after that. i would not worry about it. I have 1300 hours on mine.
/ Advice on Bobcat CT225 2010 #4
It may be a simple lubrication issue, or weak springs. I doubt if it is anything more serious. Kubotas have one or more grease zerks on the HST pedal shafts.
/ Advice on Bobcat CT225 2010 #5
I love my CT 225 best tractor I ever had and i have had many. Price sounds fantastic if the tractors in decent shape and they fix or warranty any issues with that Hydro pedal. I have not had any of the Hydro problems as of yet and I have a little over 200 hours.
Just for clarity - the CT225 is a 2010 Model
/ Advice on Bobcat CT225 2010 #7
The HST pedal is an easy minor fix. The price is very good. As long as it's not that beat up I'd say it's a good deal. Equivalent to the Kioti CK25, great little tractor. Year of manufacture isn't really a concern like with cars, hours are what matter.
/ Advice on Bobcat CT225 2010 #8
Mine's a 2011. It has never completely returned to center even since new. I just got used to bringing it to neutral with my heel or toe. It's not a big deal.
..now if you're saying it stays at whatever position you leave it, that would concern me.... mine will come 90% of the way back to neutral and will creep.
I will really test out the HST pedal when they drop it off for the demo - anything else to look for? Thanks for the help.
/ Advice on Bobcat CT225 2010 #10
Corrosion around the battery terminals and battery tray.
All the filters should have been changed on the hydro ( 2 )
This unit might have the previous generation of loader on it, which had some issues with cracking in the cross member between the loader arms.
Other than that...
/ Advice on Bobcat CT225 2010 #11
Other than that...
I think the loader on the Bobcats is not Kioti, maybe Woods, so it would not have the cracking issue that the KL120 and 130 did.
/ Advice on Bobcat CT225 2010 #12
The loader on the early bobcat tractors was made by rhino. They changed from rhino to their own bobcat made loader sometime around 2010/2011. The older style loader has the curved loader arms where as the newer loader has the angled loader arms I do not know why they changed. I forgot to mention before that I did have problems with my stock bobcat brand battery. It would leak if I used the tractor on a very steep incline. This was evident from new so I replaced it with a gel type battery. I also heard of two other things on some of the early tractors. Some had a fuel injection or fuel solenoid problem can't remember exactly And heard of a couple of problems with a Hydro cooler. It's pretty much the same tractor as a Kioti CK 27 so you could research those as well I think that's where I heard of the later of the two problems I mentioned. All machines are going to have their specific issues but I think overall The bobcat tractors are top notch.
/ Advice on Bobcat CT225 2010 #13
The only major issue I know of with the Kioti CKs is the loader problem, which is almost ancient history now, and the IP issue through 2008, neither are an issue here I believe. Of course, the usual stuff with any used tractor still applies.
I know this is and old thread - I did buy the CT225 - thanks for all the help - and I love the tractor (1st one):cool2:
/ Advice on Bobcat CT225 2010 #15
Thanks for the update. I love mine to their incredible machines.
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
UNUSED IRANCH IRTPL 10000Ib TWO-POST CARLIFT (A60432)
UNUSED IRANCH...
HOMEADE 3PT DRAG (A60430)
HOMEADE 3PT DRAG...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
