Advice on batwing mower.
/ Advice on batwing mower. #1
radman1
Elite Member
midwest
JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
I am looking for a batwing rotary mower. 20' width to cover 8 row planter with 30" rows. Anything to be aware of when buying used or new? What kind of tires - air plane, laminated, foam etc. Better brands? I see mostly Rhino in my area. Will use it primarily with 105-125 pto hp tractor. Will be used to mow waterways, smaller cedar trees, corn stalks and road sides.
/ Advice on batwing mower. #2
I use a Rhino 15' to mow weeds and brush. I like the newer models with the smooth upper decks better than older units. It sure makes it easier to clean off. I use the laminated tires to prevent flats from the stobs left from the brush. Look for C/V driveline on the pto shaft. Seals, blades ect. on used. Check for how much slop is on the unit by turning the blades on one wing and seeing if there is a delay before the others start to turn. That could be a sign of bad u-joints or worn gears.
/ Advice on batwing mower. #3
I have a John Deere HX-15 (15' unit). It has been a good tool. I did have a couple yokes fail, but I guess that is normal.
One think to consider is how many hydraulics you have/need.
My wings fold together, on some you can adjust them separately.
D.
/ Advice on batwing mower. #4
Popular brands vary by region. My least favorite brand is Woods, but that's just me. The best advise I can give you is to buy a cutter with 1000RPM input speed. Much, much less driveline problems over the life of the machine. On used machines, be sure to check the CV center plate for wear, and be sure ALL the driveshafts telescope smoothly. Gearbox shafts and seals, of course. Laminated tires are great, but road rough, and float like bricks in soft ground. Airplane tires are a good compromise. Good Luck
Need to ask what is a C/V driveline? (Not familiar with that
abreviation.) I have no experience with a batwing mower and you guys are my initial source of information. Thanks for the help. My other mowers have been 3 pt. (6' and 10' rhino models.) The tractors running the mower will have either 3 or 4 rear hydraulic outlets. I assume this will be plenty.
I am kind of surprised that most mowers are available in 540 or 1000 pto. I plan on the 1000 pto given the size of the mower and hp needs.
Can I assume that my available hp will run a mower of this size at reasonable speed (5 mph) for most conditions? How fast can you mow in an open field and smooth terrain?
I noticed that rhino has a spring/shock assembly on the hydraulic lift. Is that common? It seems like a good idea to remove some stress on the wheels.
Another stupid question. Can one wing be raised and disabled when mowing ditches with the other wing down when mowing roadsides? I have country/gravel roadsides that are too uncomfortable for me to mow due to steepness but I don't want to take up most of the road when mowing. These are getting overrun with small brush and trees.
/ Advice on batwing mower. #6
You will have adequate HP for a 20' mower in most conditions. Mowing speeds are dependent on terrain, materials being mowed, desired cut quality, and HP available. Any kind of suspension on a batwing is good if designed properly. Three remote valves on the tractor will allow lift and independent control of each wing. Disabling wings independently will require disconnecting the driveshaft from the transfer gearbox to that wing.
/ Advice on batwing mower. #7
C/V Constant velocity driveline. It takes out the U-joint chatter in turns. Most brands now have the springs in the cylinder to take out some of the bounce.
3 Hydraulic outlets lets you raise the wings seperately and have height adjustment. I only have 2 so my wings are plumbed together.
You can't easily turn off 1 wing. They claim you can run them with 1 wing folded up in the up position, but I never was comfortable seeing the blades spinning like that myself. I keep it all down when mowing road ditches and adjust the heigth to keep it out of the gravel.
In the size your looking at 1000 rpm would probably be standard for your tractors, wouldn't it? I use 540 but that is what all my equipment is set up for. You should be able to do 5 mph over open fields in grass, weeds, or cornstalks pretty easily.
I have owned to 2 Rhino's and I Bush Hog brand over they years. All have been good machines. I don't really care for Woods either.(thats just a personal preference though) Landpride, Shulte and Modern are all supposed to make good machine's also. I think you can even get much larger size in the Shulte according to the ads I've seen.
/ Advice on batwing mower. #8
Batwings typically aren't as bad as smaller single-spindle mowers as far as multiple choices of models with-in each brand, but there are still a few alternatives from the "big boys".
I have three Bush Hog 2715L's. They also sell a 2615L that's just a tad bit less expensive, and a bit lighter built. I'm thrilled with the performance. We logged over 1400 hours on one last summer without the first breakdown.
Rhino (Alamo Group) builds standard, heavy, and extreme heavy duty batwing cutters. Bush Hog and Rhino collectively sell over 85% of the batwings used in commercial mowing. Woods has a bit of a tarnished reputation in that catagory. (gearbox failures, driveshaft failures, deck hinge failures, ect)
Shreding cornstalks is rough on tires. I'd suggest EITHER the airplane tires OR the segmented solid rubber ones. The latter won't do too well if you have to take the mower on a paved road to transport.
/ Advice on batwing mower. #9
Shulte has a FOURTY FOOT WIDE batwing on the market now! Shulte is part of the Alamo Group, which includes Rhino.
/ Advice on batwing mower. #10
Thanks FWJ I thought it was 40', but it has been awhile since I saw an ad for them. I didn't realize they were part of the Alamo group.
My first batwing was a Bush Hog, bought nearly worn out and I pretty well finished it off. The second was a Rhino Flex 15 Magnum that I purchased new. I replaced it with a medium duty 12-15 several years later. The medium model had as heavy a deck and gearboxes as my old magnum model and the newest heavy duty was really beefed up. The first 2 didn't have C/V drivelines, I sure like it better on the new one.
Farmwithjunk
I don't have much road travel 2-3 miles of gravel at most. I didn't realize that laminated tires are that stiff on the road until you and others mentioned it. I have them on 3 pt mowers but never down on the road. I have an pull type old paddle scraper with airplane tires and they do seem to be very durable but require high psi.
I can't imagine pulling a 40' rotary mower. There would be no end to the number of things I would run into!
chh
I did a little research on the C/V driveline. Thanks for the explaination. It certainly seems like the way to go. We have a 20' older pull type flail mower without the C/V driveline and it requires relatively wide turns due to 1000 pto and chatter.
For anyones info, the standard U-joint driveline is called the Cardan type. A C/V driveline is also referred to as a "Double Cardan" driveline by some.
/ Advice on batwing mower. #12
IMO you can't go wrong with a Bush Hog or a Rhino. We have a 20' BH, 20' JD, and a 15' Rhino. All are good machines, the only thing i've had trouble with Rhino is getting parts, and our cutter isn't that old either.
For the money BH is the way to go. We bought both our 20's new and the BH was $3000 cheaper and is just as good a cutter. The JD has a double deck design that makes it more expensive. Whichever one you get be sure to get dual wheels on the wings. 1 wheel to support that heavy wing just isn't enough, duals provide a lot better flotation and less scalping.
I finally found a batwing mower. Saw a used JD HX 15' mower advertised in my area and bought it. Was planning on a 20' but this one was in excellent shape and the price was right. It has the larger, 26" severe duty tires, dual wheels on the wings, C/V driveline and antiwindrow kit. Was used on 200 acres of CRP a few years ago and then about a mile of roadside mowing each year. I do like the sping mounted flotation the JD mower has. A spring is mounted on each rear wheel to smooth out rough terrain. Rhino and landpride place their spring on the hydraulic in the middle.
Talked with several dealers and very few had sold a 20' mower. One dealer had a new 20' rhino left over from last year but it seemed really wide and the price was just under 18K. All dealers said the same as many of you mentioned with the laminated tires - rough riding on roads and noisey. Most recommended the foam filled airplane tires.
I just hope the JD mower get along with the Case-IH tractors.
/ Advice on batwing mower. #14
It sounds like you got a good one. I have a HX-15 I bought new. I only have the single wheels on the wings. I have the severe ag tires, etc. It has been a good mower - I am glad I didn't go any larger.
D.
/ Advice on batwing mower. #15
I have a rhino batwing mower used twice with clattering in the u-joints during turns that I have heard leads to progressive failure of the u-joints. Is this a common problem resulting in failure in the u-joints (?), or is it the intolerable noise that leads to their replacement? Since I am a beginner in pasture mowing, I am curious regarding the above question.
If it is a turning wear-damage that leads to replacement of the U-joint kit I would rather replace and avoid such a problem. Noise would be tolerable, but not a known and preventable damage with cost. If it is a destructive damage problem, where can I locate these preventable replacement kits?
Thanks for your asisstance regarding my rookie knowledge.
Blackmax
/ Advice on batwing mower. #16
The u-joints are going to clatter on the turns, just try not to turn extremely sharp turns. Keep the u-joints greased and if there is no play in the u-joints they should be good. Rhino's equipped with a CV joint can be turned up to 70 deg without any noise according to the operators manual.
/ Advice on batwing mower. #17
First if your cutter does not have a CV PTO shaft then you will be limited to the Turning radius. Also some tractors PTO's are not exactly centered, they may be off center by 2" but you will find you can turn a little sharper in one direction than you can the other direction. If you have a bat-winged cutter and you will be mowing where you have to make sharp turns to avoid obstacles then a CV is a must.
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
