Buying Advice Advice on a tractor
/ Advice on a tractor #1
Rutman
Bostic, NC
Yanmar sa424
Yanmar cub cadet ex2900.
One owner.,100 hrs, FEL, hydro, box scrape.
Asking 11,000.
Only info on these is what I have read on here.
Can I get some pros, cons, opinions.
What current compacts could I compare to in size?
/ Advice on a tractor #2
Cub Cadet Ex2900
2008 - 2011 Ex Series
Compact Utility tractor
Next model: Yanmar Ex2900
Series next: Cub Cadet Ex3200
Production:
Distributor: Cub Cadet
Manufacturer: Yanmar
Original price (USD): $16,289 (2009)
Cub Cadet Ex2900 Engine:
Yanmar 1.6L 3-cyl diesel
Cub Cadet Ex2900 Power:
Engine: 28.7 hp [21.4 kW]
PTO (claimed): 22.7 hp [16.9 kW]
Capacity:
Fuel: 6.3 gal [23.8 L]
3-Point Hitch:
Rear Type: I
Rear lift (at 24"/610mm): 1,100 lbs [498 kg]
Power Take-off (PTO):
Rear PTO: live
Rear RPM: 540
Mid RPM: 2100
Dimensions & Tires:
Wheelbase: 61 inches [154 cm]
Weight: 2,550 lbs [1156 kg]
Front tire: 7-14
Rear tire: 11.2-24
full dimensions and tires ...
Cub Cadet Ex2900 attachments:
front-end loader
backhoe
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: power
Brakes: wet disc
Cab: Foldable ROPS standard. Optional steel cab.
Hydraulics:
Type: open center
Pump flow: 5.6 gpm [21.2 lpm]
Total flow: 9.9 gpm [37.5 lpm]
Steering flow: 4.3 gpm [16.3 lpm]
Page information:
Last update: March 9, 2012
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
Yanmar sticker on the FEL.
Couldn’t see sticker on the hood.
She said it was bought at cub cadet dealer and has cub cadet plaque on frame.
I think Yanmar made theses for cub cadet.
Thanks for the specs.
Anyone with experience with one?
Also what about the 11,000 price?
/ Advice on a tractor #6
Jeffy should have provided serial # info. Suggest obtaining the # so you can determine when it was built. Hours seen low, was it stored inside? Any checking or fatigue cracking on tire sidewalls? Does the hour meter function? How do the fluids look? Any maintenance records. Are tires loaded? They still used calcium in tires frequently then, There would be deterioration around valve stem, perimeter of exposed rim. If original coolant and hydro fluid is still in tractor that could be an issue?
Not an expert on used yanmar/cub cadat, but dependent upon age determined by serial # , $8000 would be fair. They are an orphan tractor but yanmar would likely market parts. Compare these specs to yanmar, same vintage, is it a rebadged model? MTD dealer may know if a warranty claim was ever submitted?
Fluids breakdown over time, if it is a 2008, coolant becomes corrosive. Hydro fluid reservoir absorbs moisture.
1500 GAL WATER TANK (A68842)
1500 GAL WATER...
500 BBL WHEELED FRAC TANK (A67714)
500 BBL WHEELED...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
HONDA generator (A64557)
HONDA generator...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2017 CATERPILLAR 980M WHEEL LOADER (A65056)
2017 CATERPILLAR...
