adjustments
/ adjustments #1
holt50
c70mcormick
If you're out there and have a c70 McCormick tractor have you had any problems with it changing gears? Mine doesn't want to change when i take it out of low high or reverse it won't go back in any of the ones mentioned. Ibushoged and I probably messed with the cable that goes from rear to clutch pedal . I need to know how to adjust I have had it as long as possible [cable] and as short as it can be and it wont go in gear unless I pull out on the cable .where the cable hooks on theres a sleet place in it and the pedal bottoms out before the cable moves. I put a small bolt in to take up slack and changes but not good and I 'm not much to cobble up things , McCormick USA is of no help email me if you know how to adjust it ,it would be nice to have some instructions on paper for future us Thanks holt 50 email is holtroger@ymail.com
