adjustment of 3pt cat 1 hitch
   / adjustment of 3pt cat 1 hitch #11
Are you on level ground? How is you side link adjusted?
   / adjustment of 3pt cat 1 hitch #12
Well in the middle of the night an edit appears and you are using a quick hitch that is good to know.
I f you would post a few good pictures I am sure we can come up with the best way to solve your fit issues.
   / adjustment of 3pt cat 1 hitch #14
Some clarification is needed:
Is the implement too far to the left (when you are sitting in the seat; facing forward)?
If so, you may need to adjust your chains, stay strap or adjustable stabilizer bar, depending on how your hitch is configured:
Click on this one:
As you can see, there's more than one way to skin a cat, so a picture of your hitch would be helpful.
   / adjustment of 3pt cat 1 hitch #15
It almost sounds as if he is using an offset attachment, where he hooked up to the bottom pins but the top is off.? I think I could be wrong.
John Deere 1600 Turbo Series II (A57453)
John Deere 1600...
8065 (A55852)
8065 (A55852)
404 (A52706)
404 (A52706)
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
