adjustment of 3pt cat 1 hitch
   / adjustment of 3pt cat 1 hitch #11
Are you on level ground? How is you side link adjusted?
   / adjustment of 3pt cat 1 hitch #12
Well in the middle of the night an edit appears and you are using a quick hitch that is good to know.
I f you would post a few good pictures I am sure we can come up with the best way to solve your fit issues.
   / adjustment of 3pt cat 1 hitch #14
Some clarification is needed:
Is the implement too far to the left (when you are sitting in the seat; facing forward)?
If so, you may need to adjust your chains, stay strap or adjustable stabilizer bar, depending on how your hitch is configured:
Click on this one:
As you can see, there's more than one way to skin a cat, so a picture of your hitch would be helpful.
   / adjustment of 3pt cat 1 hitch #15
It almost sounds as if he is using an offset attachment, where he hooked up to the bottom pins but the top is off.? I think I could be wrong.
Pickup Truck (A59230)
New/Unused 12 Ton Hydraulic Jack (A57454)
New/Unused 12 Ton...
2.5 POLY PIPE (A58216)
2014 Freightliner 108SD Crane Truck, VIN # 1FVHG5CY3EHFL1495 (A57453)
2014 Freightliner...
CAT 336E (A58214)
CAT 336E (A58214)
Winchester Metal Sign (A57454)
Winchester Metal...
