Adjusting loader arms for quick attach alignment
/ Adjusting loader arms for quick attach alignment #1
TXBrad
Wolfe City, TX
Kubota L2501
New tractor owner and first post. Been lurking for while.
While clearing some brush a limb caught my quick attach levers and my bucket fell off.
When I tried to get it back on I noticed one of my loader arms is 5-6 inches higher than the other and the quick attach plate is also curled more than the other making attaching the bucket much harder. Not very quickish...
My immediate thought was that the hydraulics are just not in "sync" and the pistons in the cylinders are not in the same position.
Any way to adjust this?
Thanks in advance
/ Adjusting loader arms for quick attach alignment #2
Roll them all the back and get them the same, your plate may be bent. If you cycle your loader arms all the way in or all the way out it might help, not gonna say fix it. I had this happen to a grapple bucket on a skidsteer once and had to do a little cutting/welding to relieve the stress. Post some pictures if you can.
/ Adjusting loader arms for quick attach alignment #3
There is a round rod that connects the two sides of the quick attach, known as the "timing" rod since it's meant to keep the two sides aligned. Yours has gotten twisted because of what happened. You either need to twist it back, or cut it off and re-weld it back into the proper alignment.
Normally when the happens, it's a minor twist, but if you are out of whack 5-6" across the two sides, maybe the damage is more serious.
/ Adjusting loader arms for quick attach alignment #4
BTW, this is a common rookie mistake with tractors, so don't feel too bad. I bet it won't happen again.
Ahh that makes perfect sense. I bet that's what it is. Gives me great place to start.
Thanks so much for the input.
2016 P.J. Trailer Trailer, VIN # 4P5F8202XG1252798 (A65563)
2016 P.J. Trailer...
Mitas Tire (A65640)
Mitas Tire (A65640)
Red Oak Boards (A65640)
Red Oak Boards...
90in. Work Bench (A65640)
90in. Work Bench...
Case IH 4200 Combo Mulch-Soil Finisher (A66285)
Case IH 4200 Combo...
2015 Chevrolet Silverado Flatbed Truck, VIN # 1GB4KZC87FF627659 (A65563)
2015 Chevrolet...
