Additional Hydraulics
/ Additional Hydraulics #1
ch47dpilot
Enterprise Alabama
09 Kubota L3400
I have a Kubota L3400, the hydraulics is rated at 6.3 gal/min. I was looking at hydraulic motors on Surplus center and most run about double that. Other than a PTO driven Surplus Center - 9.9 CU IN PRINCE HC-PTO-1AC PTO PUMP CI 540 RPM is there other options people have used. The pump is about $500 plus I'll need aux tank,filters, hoses ect.
I have one other question on this topic. If I run a lower flow rate will I lose torque? My understanding is PSI creates torque and flow will affect RPM. The motors run about 10x faster than I need. Can I just reduce the flow from 6.3 to what ever I need and not loose torque? Assuming PSI can be maintained at 2000psi?
/ Additional Hydraulics #3
You're understanding is correct. You will loose some torque at slower flow rates because efficiency is reduced. 1/10 of rated flow is kind of extreme though. Its always better to run a motor close to its rated rpm. I expect there is a chart somewhere that would tell you what to expect out of that motor with reduced flow.
Kim
2021 Felling FT-45-2LP 29ft. 26 Ton Tag Trailer (A64194)
2021 Felling...
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
2013 Nissan Pathfinder SUV (A64557)
2013 Nissan...
213063 (A64276)
213063 (A64276)
UNUSED PARBREAK AR650 HYD AUGER SET (A65055)
UNUSED PARBREAK...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
