Additional Hydraulic ports
/ Additional Hydraulic ports #1
JimC
Seguin, TX
Kubota BX2200
Has anyone added a additional hydraulic port to a BX2200.
Looke like it would not be too difficult a project.
Sure would be nice to be able to add things like a log splitter etc to the machine.
/ Additional Hydraulic ports #2
Jim, Search the files. I read it somewhere on here.
I'll try to find it. The guy used BX22 parts.
/ Additional Hydraulic ports #4
Keep us posted if you do. I probably will also. I'm going to build a Caddigger BH for my BX. If you need more part numbers and schematics, you can get them from TractorSmart through links like this one:
<A target="_blank" HREF=http://www.tractorsmart.com/downloads/BX2200D.pdf>http://www.tractorsmart.com/downloads/BX2200D.pdf</A>
/ Additional Hydraulic ports #5
JimC.
It only took me about an hour to install all the parts which included fabricating the brackets that the hard lines are fastened.
/ Additional Hydraulic ports #6
how hard do you think it would be to add to a L3710? Cost for parts?
/ Additional Hydraulic ports #7
MDSteve.
Your L3710 would be a bit more involved and more expensive because you would actually be adding additional Selective Control Valves(SCVs which is better by the way) I think you can add 2 or 3 more valves, but someone who actually has a L3710 could tell you for sure. It's more expensive because of the valves themselves and the extra hard plumbing that goes along with them.
Woods Brushbull 60 3Pt Mower (A66285)
Woods Brushbull 60...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
